August 16, 2017, 02:13 |
non convergence in solving
Rep Power: 10 |
Dear Friends
I have been getting involved in simulating end-winding of a generator. as you can see in the two pictures below I have one domain and a part of the end winding. my boundary conditions are as follows: inlet: mass flow rate (from 1 to 20) outlet: opening pressure upper and lower parts: periodic left and right sides: wall flow: air 25 heat transfer: thermal energy turbulence: K-e by the way I have not used boundary layer mesh for not reducing the quality of mesh in mass flow rate of 1 i did not have any problem in convergence, but by raising the mass flow rate to 6, the RMS of equation decreased up to 1e-3 not lower. although I have tried a lot recently, I could not find any solution now i am asking is there anyone help me?? thanks in advance |
August 16, 2017, 06:22 |
Rep Power: 143 |
None of your numbers have units. Numbers without units are pretty meaningless.
Your question is an FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria Your comment about not having inflation layers is almost certainly a mistake. You should fix this is if are looking for any accuracy in your simulation. |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
