November 14, 2012, 10:11 |
Should I use the transitional turbulence?
Hope
Rep Power: 13 |
Hi. My job is to use CFX and model a 0.9*0.1*14m wind tunnel, inlet V=9.7m/s, outlet pressure=0. TO see the outlet profile. When I use SST, should I use the transitional turbulence? And which one should I use.
Also could anyone help me about that, or give me some basic information about transitional turbulence? I didn't find enough information in the help files. Thank you! |
November 14, 2012, 16:47 |
Rep Power: 143 |
Only use the transitional turbulence model if you think you have a turbulence transition and it plays a significant part in your flow. If not forget about it.
There are some papers on the turbulence transition model in the CFX customer portal and/or available from CFX support. |
cfx, transition turbulence, wind tunnel |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model | josechen | FLUENT | 0 | July 20, 2011 16:06 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
How to set the transitional turbulence for blades | Hermann | CFX | 3 | January 5, 2006 14:06 |
