A problem
Like Tree1Likes
  • 1 Post By evcelica
Old   October 31, 2012, 08:27
Default A problem
liuzexiang
liuzexiang is on a distinguished road
hi,i am a beginner for CFX. i am doing a the coupling of the flow field and electric field simulation. the question is :the conductive liquid through a metal piple connecting cathode of power supply flows to another metal connecting anode of power supply and there is a gap between them. the flow field model is established in workbench and is analysed in CFX. the molar,density,specific heat,dynamic viscosity,thermal conductivity ,electrical conductivity and convection coefficient are setuped,but there is no result at all. i can not understand why? Maybe the setups are wrong! i tried to find out the problem,but no result ,so i need some help! thanks
liuzexiang is offline   Reply With Quote
Old   October 31, 2012, 11:40
Erik
evcelica is on a distinguished road
Is the solver manager giving you an error and exiting? What do you mean by "no result"
liuzexiang likes this.
evcelica is offline   Reply With Quote
Old   October 31, 2012, 22:35
Smile
liuzexiang
thanks,the error is follow:
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR
An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created.
Old   October 31, 2012, 23:27
liuzexiang
when i onlydo the flow field simulation in workbench,the error is follow:The CFX Solver for system Fluid Flow did not produce a results file. the details is :
Ans.Core.Commands.UserReadableFailure: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
在 Ans.CFX.CFXCore.Data.CFXSolutionSource.HandleRunFa ilure(CommandContext context, String outFileName, String rawSolverOutput)
在 Ans.CFX.CFXCore.Data.CFXSolutionSource.ReconnectRu n(CommandContext context, SolverBackgroundTask task)
在 Ans.CFX.CFXCore.Data.CFXSolutionSource.RunSolver(C ommandContext context, Boolean forceResume)
在 Ans.CFX.CFXCore.Data.CFXSolutionSource.Update(Comm andContext context)
在 Ans.CFX.CFXCore.Commands.UpdateSolutionCommand.Exe cute(CommandContext context)
在 Ans.Core.Commands.Concurrency.CommandWorkUnit.exec uteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
在 Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecu te(IExecutionEngineCallback executionEngine, CommandContext subContext)
在 Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute (IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
Command: CFX.UpdateSolution(Container="Solution")
在 Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
在 Ans.Core.Commands.CommandAsyncResult.Wait()
在 Ans.ProjectSchematic.Data.CellTemplateEntity.Updat e(CommandContext context, IProgressMonitor progressMonitor, DataContainerReference container, List`1 downstream)
在 Ans.ProjectSchematic.Update.UpdateImpl.updateCell( CommandContext context, UpdateTask task)
在 Ans.ProjectSchematic.Update.UpdateImpl.<>c__Displa yClass25.<updateCellAndDependencies>b__24()
在 Ans.ProjectSchematic.Update.UpdateImpl.executeWith SelectedErrorBehaviour(Op op, UpdateTask associatedTask).
the memory of my computer is 3G,and the virtual memory is 4606 M
Old   November 4, 2012, 03:46
liuzexiang
what is the error?
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
