November 26, 2012, 23:08 |
Monitor Point Data and res Discrepancy
Rep Power: 13 |
I was simulating a transient flow. I set up a monitor point at a certain location to monitor the velocity. After the flow had been solved I exported the monitor point data from the CFX solver manager. When I went to CFX post and plot the velocity at that same location versus time and then exported that data, I found the velocities to be totally different from the ones I got with the monitor points, but they are at the same location. Can anyone tell me what I'm doing wrong? I'm using CFX 14. Thanks a lot.
November 27, 2012, 05:11 |
Rep Power: 143 |
How much different are they?
I am pretty sure the solver monitor point just uses the nearest nodal value but CFD-Post interpolates, so if the flow has steep spatial gradients this would explain some difference. |
November 27, 2012, 13:30 |
Rep Power: 13 |
Thanks for the clarification. The values at every timestep were different but I calculated the RMS value of the velocity they were off by 1% ish. I guess I can consider them the same.
how to export data from CFX-post | Rachel_09 | CFX | 4 | October 16, 2017 14:46 |
Visualise CFX res files | salihovic | CFX | 3 | July 16, 2010 08:35 |
export data from cfx-post | Rachel_09 | CFX | 5 | September 11, 2009 13:17 |
Initial field from res file by "node to node" reading | Nevel | CFX | 1 | June 16, 2009 07:59 |
heat conduction in solid - mismatch to exp. res. | Ralf Schmidt | FLUENT | 1 | December 9, 2008 08:34 |
