Temperature depending on x,y as boundary condition in Steady-state Thermal simulation
Old   November 29, 2012, 10:18
Default Temperature depending on x,y as boundary condition in Steady-state Thermal simulation
Deutschland
FluidCFD is on a distinguished road
I'd like to add a varying temperature distribution depending on the x and y direction as a boundary condition in a steady-state thermal simulation. When I add "Temperature" to the "Steady-State Thermal" folder in the "Setup" step I can only make it dependent from x or y, but not from both. Can anybody tell me whether it is possible to add a 2D temperature distribution? It should be something like T1-x^2-y^2.
Best regards
FluidCFD is offline   Reply With Quote
Old   November 29, 2012, 10:47
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Yes using CEL this is possible.
cdegroot is offline   Reply With Quote
Old   November 29, 2012, 11:32
Bruno
brunoc is on a distinguished road
Originally Posted by FluidCFD View Post
Best regards
Seems like you're creating your model in Mechanical. This is the forum for CFX. You can do that simulation in CFX using a CEL Expression, as Chris mentioned, and it is quite straightforward.
brunoc is offline   Reply With Quote
Old   December 3, 2012, 05:27
Deutschland
thanks to you both. I first tried to do it in CFX and with the help of CEL, then had some other problems and thought, Steady-state Thermal is designed to do exactly what I want to do. Apparently, it is easier to implement in CFX than in Thermal analysis. I got it running now.
Another question: When I want to know the heat flux at an arbitrary plane, is the one displayed normal to that plane?
Best regards
Old   December 3, 2012, 09:38
cdegroot's Avatar
Chris DeGroot
Glad you got it running. I'm not sure I understand your current question. If you define a plane, the heat flux reported will be the heat flux through that plane.
Old   December 3, 2012, 10:12
Deutschland
Yeah, that was my question. Can you also tell me what the difference between heat flux and wall heat flux is, as the heat flux is often "not defined" and I don't understand why.
Old   December 3, 2012, 11:01
Bruno
Heat fluxes come from the solver, they're not calculated by CFD-Post, and I think the results file don't include that field. You can calculate it yourself, though. Just create one variable that calculates the temperature gradient, and another one that does the rest of the calculation (heat flux by conduction, advection, etc).
Cheers
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
