March 15, 2013, 12:30 |
Non-local thermal equilibrium
Troll_Warlord
Rep Power: 13 |
How do I enable the non-local thermal equilibrium model in CFX-13?
Does CFX use local-thermal equilibrium or nlte to model porous behavior? I could find this information stated explicitly on any of ansys's sites or any user forums. could someone help me with this? |
March 16, 2013, 04:54 |
Rep Power: 143 |
If you activate the heat transfer in fluid and solid model then it is non-local thermal equilibrium. If it is not activated then you are assuming local thermal equilibrium. So CFX can use either approach.
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
