March 25, 2013, 03:50 |
a problem about CFD-post
Ben B. Huang
Rep Power: 13 |
hey,
I have a problem here in post-poccessing. I do not know how to export velocity contour lines data, say, v=0.2 m/s. I'd like to compare zones specified by velocity threshold value of different cases, and I can not find a way to export the contour lines of interest (eg. level 2 or 3). could anyone help me for this ? I will appreciate it very much. thank u. |
March 25, 2013, 08:27 |
Edmund Singer P.E.
Rep Power: 20 |
Create a user surface based on contour level (level value is your choice).
For the contour objext, I suggest using list values for the contours so that you can control the level of the user surface precisely. Export the user surface. |
March 25, 2013, 08:32 |
Ben B. Huang
Rep Power: 13 |
Thank you so much for your reply. I'll try in that way.
March 25, 2013, 10:14 |
#4 | |
Rep Power: 19 |
if you only want the contour line for a level, create a polyline based on the contour level.
Thiagu
Rep Power: 13 |
thanks "singer1812 & Hwangpo" . It is working
March 25, 2013, 23:03 |
Ben B. Huang
Rep Power: 13 |
I tried with polyline method but it didn't work anyway because I wanted to export velocities and locations in order to draw some pictures using them.
I will try it again by the way and thank u so much. |
cfd-post, contours, export data |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 12:06 |
Collect transient results CFD POST | mortain | CFX | 15 | April 17, 2015 08:29 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
CEL mathematical functions in CFD Post | Jonathan | CFX | 9 | November 5, 2012 08:37 |
flap meshed with shell > surrounding CFD Mesh has weird look in CFD Post | MainzerKaiser | CFX | 1 | April 26, 2012 13:18 |
