transitional turbulence for turbomachinery
Old   April 1, 2013, 06:36
Default transitional turbulence for turbomachinery
Benny
Benfa is on a distinguished road
I am thinking about Reynoldnumbers at which transition from laminar to turbulent in turbomachinery occurs. For a flat plate it starts about 5e4 and for pipes at 2300. The simulation is a fan with incompressible air. For sure it depends on the initial degree of turbulence and roughness, etc. but maybe anybody has experience or rule of thumb that could help to estimate if it is necesarry in the simulation. The Reynoldsnumber (tip diameter and velocity) ist about 7e5 for the fan so I would not expect so much laminar flow but the comparison with exp. pressure date shows better agreement using a sst transition model instead of sst.
Benfa is offline   Reply With Quote
Old   April 1, 2013, 18:38
Have a look at the Re across the blade chord. If that is more than about 1e5 then I would think transition occurs on the blade - assuming it is a aerodynamically shaped blade.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Should I use the transitional turbulence? hopehope CFX 1 November 14, 2012 16:47
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model josechen FLUENT 0 July 20, 2011 16:06
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
