need to get sufficient results in 3D with TET
Old   April 10, 2013, 10:32
Default need to get sufficient results in 3D with TET
Dmitry
imnull is on a distinguished road
I need your advice.. My 2D HEX model and experiment are in agreement.
Nevertheless I need 3D. I am not good in ICEM to make 3D HEX (I have lots of freaking steps in geometry..). So I did 3D TET, results in numbers are not matching with 2D HEX.. but I would say If to refine the mesh, the results 3D TET will match to 2D HEX (I did try it already, with an increase of elements the results getting closer to 2D HEX). But, the way to refine TET is not good for me I already have 2.1M TET.. so if I put in *.def mesh adoption option.. will it helps to safe computing time to get results close to 2D HEX..? any advice are welcome thanks for your time. Thanks.
P.S. btw: i do model supersonic flow, with max M~2.5.
imnull is offline   Reply With Quote
Old   April 10, 2013, 11:43
OJ
oj.bulmer will become famous soon enough
21 million mesh!!? Are you sure?
You don't have to refine the mesh at every corner. Have a look at your 2D results and understand where you have larger gradients, and try to refine only there. Or, try mesh adaptation.
OJ
oj.bulmer is offline   Reply With Quote
Old   April 10, 2013, 12:21
Dmitry
OJ
yes my 3d tet has around that value.. i do have a blade with 16 cores and 36GB.
pls take a look on results of 2D HEX
as seen I have 5 areas... so, at each freakin corner.. hope you see the problem with using TET now..
my run with mesh adoption is still on (2 days already).. converging process is ok (i do control it manually). will report on results.. do you have an experience to work with supersonic flow (I have some more @stupid@ questions)?
Old   April 11, 2013, 09:57
Thumbs up
Dmitry
calculation with mesh adaptation is done... yes, adaptation helps.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 08:32
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 08:15
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
