how to increase "Newton Pressure Iteration Limit"
Old   February 1, 2007, 04:43
Default how to increase "Newton Pressure Iteration Limit"
kus
I am running a big mesh simulation (nodes: 40300) with two domain interfaces. it is a gas mixture flow and particle tracking only simulation.
In the first iteration, the out file gives the information as below,
| The Newton iteration was either slowly converging or has stalled. |
| The solver will continue with the variable set as it was on the |
| final iteration. If this situation continues you might try |
| increasing the number of iterations allowed for Newtons method. |
| This can be changed by setting one of the parameters: |
| Temperature : "Constitutive Relation Iteration Limit" |
| Pressure : "Newton Pressure Iteration Limit" |
| for your mixture using the definition file editor. |
According to this message, I am trying to increase the number of iterations for Newtons (Constitutive Relation Iteration Limit and Newton Pressure Iteration Limit) for a material. But I cannot find them in CFX-Pre.
Then I had to search them two in CFX-HELP. The HELP (Reference Guide | ANSYS CFX-Pre CCL Details | CCL Objects |) says as below,
Using the CCL Content Documentation: This document is generated from the CFXPreRules.ccl file in the ANSYS CFX/etc/ directory. It contains a description of all the possible CCL objects and parameters.
But any modifications are prohibited in CFXPreRules.ccl .
Anybody are experienced in this? any suggestion on this problem?
Looking forward to you reply. Thank you very much in advance.
Old   February 15, 2007, 14:50
Default Re: how to increase "Newton Pressure Iteration Lim
Georges
If you go into you defenition file editor from post, u can add a paramether to one of your mixtures. The Newton Pressure Iteration Limit can be modified from there.
Old   February 15, 2007, 18:30
kus
Dear Georges,
I just cannot find how to add a parameter to my gas mixture in POST. Could you give more details. Thanks a lot.
Ben
Old   February 16, 2007, 08:17
Georges
Sure, When you open up Post, go to "tools/edit definition file". Once you have your file open expand the library then select the gas mixture. Once you've done that, click on Edit/Add Paramather. Hope that helps.
Old   February 18, 2007, 18:06
kus
Dear Georges,
Thank you for your quick response.
Are you using the CFX5 versions (CFX10.0 and CFX11.0)? I cannot find the library in these versions and thus cannot add parameters to gas mixture. Looking forward to your reply.
Ben
Old   February 28, 2007, 15:59
Georges
Hey, I'm using CFX 10. Do you not have the Edit/Add Paramather Option ?
Old   February 28, 2007, 19:08
kus
Hi Georges,
I found it. Thanks a lot. May I have you email for future contact?
Old   June 15, 2009, 07:09
Thumbs up
zhang tw
slurry is on a distinguished road
Originally Posted by Georges
;80370
Thank you. I have that question. I solved according to what you said.
slurry is offline   Reply With Quote
Old   February 15, 2013, 06:49
Default Now in Solver
Anton Persson
antonpersson is on a distinguished road
Thank you!
In CFX 14.0 this is done in CFX-Solver Manager. Go to Tools -> Edit CFX Solver File -> Select your material -> Edit -> Add Parameter
BR,
Anton
antonpersson is offline   Reply With Quote
Old   April 21, 2013, 01:54
Default Newton Iteration slowly converged
BhaskarD
Magma is on a distinguished road
Send a message via Skype™ to Magma
I have been working out with the tutorial in coal combustion.
I have been receiving the following message:
And I edited the file too, but what is the Constitutive Relation Iteration Limit for temperature and Newton Pressure Iteration Limit for pressure or what does that mean.
The next problem is the solver runs and stalls after 25-30 iterations with this message in serial mode and does not run in parallel mode. I have set expert parameters for memory allocation too.
What might be the problem? Help would be appreciated.
Magma is offline   Reply With Quote
Setting minimum absolute pressure limit meteo45fr STAR-CCM+ 2 May 25, 2009 02:59
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
