one face turn to be two in pre
Old   May 16, 2013, 04:04
Default one face turn to be two in pre
leo
sjtusyc is on a distinguished road
I am simulating the flow field of a large room. There are several pipes in the room. Air flows from the large room to the outer environment through pipes.
I try to start with an easy model.
First i model the room and then i direct model one pipe in the room through UG.
When meshing, I creat two material bodies, one for the pipe, and the other for the big room.
And i named the the inlet face of the pipe which connects the big room as IN.
But when i load the mesh in the CFX-pre, I found the CFX named the IN as
IN-a,IN-b.
Why will that happen?
Is it OK?
sjtusyc is offline   Reply With Quote
Old   May 16, 2013, 04:36
OJ
oj.bulmer will become famous soon enough
This is probably because the IN surface is shared by two domains (materials) here - pipe and room. Hence a and b sides belong to the two domains meeting at your surface.
As long as both are same materials, ie air, you should be fine.
OJ
oj.bulmer is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
