CFD analaysis of Pelton turbine
Like Tree2Likes
Old   April 30, 2013, 03:16
Post CFD analaysis of Pelton turbine
Amod Panthee
amodpanthee is on a distinguished road
Does any body have link for references to execute cfd analysis of Pelton turbine using ANSYS CFX? Any link for tangential flow turbines like turgo turbines might be beneficial.
anaj likes this.
amodpanthee is offline   Reply With Quote
Old   April 30, 2013, 09:26
OJ
oj.bulmer will become famous soon enough
Have a look at the CFX tutorials, they provide ample information.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 1, 2013, 07:59
Amod Panthee
Is there any specific tutorial for tangential flow turbines?
Old   May 1, 2013, 08:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I think there is no specific tut on pelton turbine. For pelton turbine you have to model full wheel and place the jets at appropriate location. Placing GGI between jets and wheel may not be recommended but you can try.
Meshing definitely would be the most time consuming part.
Make the CFD model (meshing, boundary conditions) and come back to further details. If you need help in meshing, you are also welcome.
Far is offline   Reply With Quote
Old   May 1, 2013, 08:57
Default domain
Amod Panthee
[IMG]file:///C:/Users/RENP-PID-437-1/Desktop/domain.JPG[/IMG]
Old   May 1, 2013, 09:00
Default domain
Amod Panthee
I have set the domain as shown in the pic....Is it OK to simulate with it?
Old   May 1, 2013, 18:34
This will probably work, as long as you only want to model 5 blades.
It can probably be optimised somewhat by doing a few things:
1) Put a wall instead of your outlet, excpet for at the bottom. This will converge much easier and should not affect things too much.
2) You probably do not need to model the nozzle in too much detail. I would just make it an inlet with the necessary velocity - unless the small velocity distribution across the jet is important.
Old   May 2, 2013, 07:39
Default trial simulation
Amod Panthee
I am running a trial on the model. The boundary conditions are set as shown in the attachment. It gave an unexpected result. Why is the direction of jet changed when it passes from stationary domain to the rotating domain. I think I have some problem with rotating domain.
I have 22 buckets rotating at 600 rpm and 2 nozzles of which I took 5 buckets and lower nozzle. The nozzles are not in symmetric locations. How to choose pitch value in such cases?
Old   May 2, 2013, 15:16
Far
Sijal
At-least you need eleven blades and one nozzle. If nozzles are not symmetric then you need to use full wheel with two nozzles.
Old   May 2, 2013, 18:44
The jet is not straight because you are plotting velocity in the local frame of reference. To get a straight jet plot in CFD-Post using "Velocity in Stationary Frame of Reference".
Old   May 2, 2013, 23:45
Default velocity in stationary frame
  #11
Amod Panthee
The direction does not change when we see it in stationary frame too
Old   May 3, 2013, 01:58
Far
Sijal
did you give the rpm to runner?
Old   May 3, 2013, 02:55
Amod Panthee
Yes of course..... Runner is rotating in anticlockwise direction. I have assigned value 600 rpm.
aichiteiru likes this.
Old   May 5, 2013, 05:14
Default Flow Direction
  #14
Amod Panthee
I have problem with the direction of jet at interference between rotating and stationary domain, attached picutre. I think I have problem with defining the flow direction at Inlet.
I was trying to simulate a complete runner and got an error on setting the cartesian co-ordinates 0,0,0, attached picture. So, I tried simulating taking normal to boundary which runs, attached picture.....I ran it although it does not give desired result. So, I think the flow direction is the reason for deflecting the jet.
Is there any rule of thumb like right hand thumb rule or left hand thumb rule to define the flow direction? The two jets in my model are placed inclined at an angle 45 degree in second quadrant and third quadrant in XY plane. Changing the flow direction will probably help run the simulation correctly.
Any suggestions would be highly appreciated.
Old   May 5, 2013, 06:03
Default Pelton
  #15
BhaskarD
Magma is on a distinguished road
Send a message via Skype™ to Magma
Sir, What I believe is : if you are working with Cartesian coordinates, you must specify each components of velocity!! cheers!!!
Magma is offline   Reply With Quote
Old   May 5, 2013, 07:36
Just use normal to the boundary for the inlet. No need to specify a direction.
Your jet is being deflected before it even gets to the pelton blades. This means something is fundamentally wrong with your setup to do this. What are streamlines of the air phase look like? If you have over-constrained the air phase it will deflect the water jet like this. I mean the air needs somewhere to go to get out of the way of the water jet.
Old   May 5, 2013, 09:44
Far
Sijal
Why are you using symmetry condition? if it strange to use symmetry condition for this type of flow where you don't know exactly where flow is going...
My suggestion :
we did similar study on tip injection effect on stall margin enhancement of transonic axial compressor rotor ( to be specific, NASA rotor 37)
http://arc.aiaa.org/doi/abs/10.2514/6.2012-329
http://www.researchgate.net/publicat...ow_Compressors
The point which I want to discuss is that " we have divided tip clearance into two parts : one was with rotating domain of rotor and second was with stationary domain of tip injection. So instead of putting interface at the intersection of jet and casing of compressor we gave it some space into the rotating domain.
I can locate that paper and send you if needed.
Old   May 5, 2013, 23:36
Default paper
  #18
Amod Panthee
Far
Can I get the full length paper? amodpanthi@ku.edu.np
Old   May 10, 2013, 13:18
Far
Sijal
Sorry for delay. did you get paper?
Old   May 11, 2013, 02:46
Amod Panthee
Yes, I received the attachment. I am going through it.
Thank you
cfd, pelton turbine, tangential flow turbines
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 08:34
Helical Turbine CFD gkadoo Main CFD Forum 0 April 22, 2010 03:28
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 06:41
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
