parametric analyses in ansys workbench and CFX |
April 30, 2013, 12:37 |
hamed
Rep Power: 17 |
Hi
Does anyone know how it is possible to run several analyses in cfd using Parameter set available in ansys workbench? I know i can set some dimensional parameters in my model and also in mesh program but i don’t know how to define results as an output parameter |
April 30, 2013, 17:28 |
Erik
Rep Power: 23 |
In CFD post, you can make an expression for an output parameter, example max(Temperature)@plane1 then right click the expression and click "set as workbench output parameter"
You may be able to do this in CFX Pre as well, but I've never tried, I like to check the first round of results first. |
May 1, 2013, 23:51 |
hamed
Rep Power: 17 |
tanks for the clue
i have tried what you said .i found the output parameters but there is still a problem a.while iset some design points and push the update all design points ,Ansys begins solving all the design points and the lightening sign disappears from design point's parameters one by one but no value is shown for output parameters at last. Where is the problem? Best regards |
May 2, 2013, 11:37 |
OJ
Rep Power: 20 |
You need to wait till the solution is stopped, it's only then the results are fetched from CFD-Post. Try clicking on the parameter tab below Results, you will see your updated results.
OJ |
June 5, 2013, 09:43 |
Matthias Voß
Rep Power: 20 |
one more fact: afaik if you add ANY additional output to your already solved cfd-post container it will still solve again instead of just reading the res-file again.
neewbie |
June 21, 2013, 15:17 |
Rep Power: 13 |
Does anybody know, if I can use a Parameter set on inportat solid with in the ansys design modeler.. For example I can use the Extent Type on a extrusion which I have created with the design modeler but I can´t find a way to so with my imported solid.. any help would be very much appreciated!:9
June 21, 2013, 16:09 |
#7 | |
hamed
Rep Power: 17 |
June 24, 2013, 10:45 |
Matthias Voß
Rep Power: 20 |
activate the parameter import in the wb2.0-schematic and set the correct key (e.g. DS_...) for the wb to recognize your parameters with this key from imported CADdata and set them as parameters in DM.
June 24, 2013, 14:22 |
#9 |
hamed
Rep Power: 17 |
have you ever imported catia part files into WB? do you know what is the catia part files correct key?
June 24, 2013, 15:11 |
#10 |
Matthias Voß
Rep Power: 20 |
Never used Catia but proE and sw. You can set the Key to whatever you like from the wb-schematic. Just Right-Click for the Options menu.
June 24, 2013, 16:46 |
#11 |
Rep Power: 13 |
if the keys don´t show up, does that mean that the catia-wb interface wasn´t installed to begin with? and we are talking about linking the cad model with wb and no igs import, right?
June 25, 2013, 05:14 |
#13 |
hamed
Rep Power: 17 |
yup. that's what we are talking about.we want to know if there is a way to define solidwork or catia part's dimensions as a parameters in workbench or not.
June 25, 2013, 05:16 |
#14 |
Matthias Voß
Rep Power: 20 |
please have a look at the link above. Define the parameter names in SW/CATIA with the key u like and set that key in the wb-schematic.
April 18, 2016, 08:13 |
#15 |
alex
Rep Power: 10 |
hi guys
I want to simulate flow over my wing for various angle of attack at different velocity. people suggested i have to look for parameters study in work bench. my case is i want to input various velocities for particular angle of attack. when I searched there are ways to change parameters in design modeler. i dont want to change my mesh. is there a way to change input velocity from workbench parameters study. can u send any tutorials for that? |
April 18, 2016, 20:23 |
#16 |
Rep Power: 143 |
You can set parameters in CFX-Pre as well. Have a look at the workbench tutorial examples on parametric modelling for tips on how to set this up. They are available on the ANSYS community webpage.
April 19, 2016, 03:24 |
#17 |
alex
Rep Power: 10 |
found it.thanks a lot.
April 19, 2016, 03:33 |
#18 |
alex
Rep Power: 10 |
Any help on stability and control derivatives estimation glenn.
April 19, 2016, 06:22 |
#19 |
Rep Power: 143 |
The derivative against AOA is simply got from a sweep of AOA. If you want the time dependant ones then you need to do transient simulations where you model the appropriate motion and get the lift/drag from that.
April 19, 2016, 07:42 |
#20 |
alex
Rep Power: 10 |
I am getting a error in parametric simulation.
"update of solution component in CFX for design point failed. A conflict exists between the execution control in this component and the upstream component.this can be resolved by right clicking on solution cell and choosing an option from edit run defintion menu". |
Export Heat Flux CFX -> ANSYS Workbench | Freeman | CFX | 2 | April 11, 2010 08:24 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
FSI in Ansys Workbench + CFX v.11 | nasdak | CFX | 3 | June 22, 2009 08:44 |
Ansys Workbench (CFX) bucket problem | njsavage | CFX | 1 | April 30, 2009 09:51 |
I cannot open Ansys CFX in Workbench | Pham Son Minh | CFX | 2 | January 13, 2008 03:33 |
