April 30, 2013, 14:43 |
Radiation Properties of MultiComponents
Hello!
I write to ask about the configuration of the radiation properties of a reactive mixture. I'm modeling internal flow combustion in a boiler, after selecting the turbulence model and define the emissivity of the walls, the program gives me this warning: "In Analysis 'Flow Analysis 1' - Domain 'Default Domain': Radiation properties for the Mixtures 'reaction mixture' will be based on a mass weighted average of the constitutive components, Unless overridden with explicit Mixture Property settings." Reading the CFX help I found that by default the program calculates the radiation properties through a weighted sum of its components, which computationally is not recommended (my simulation has 10 components). I wonder who could give me recommendation to avoid this problem, or how to calculate these properties. Greetings. |
April 30, 2013, 19:39 |
Rep Power: 143 |
Unless you have a better model of what the mixture properties are then why not just accept the default?
May 1, 2013, 22:19 |
Erik
Rep Power: 23 |
Right, I don't see why that would make it that much more computationally expensive. taking the average of 10 values is not hard far a computer to do considering all the other calculations its performing.
It has to do this for every other material property anyways, so whats the big deal? |
May 27, 2013, 11:35 |
Ok.
I thought these calculations represented a high computational cost. Greetings!!! |
cfx, mixture, multicomponents, properties, radiation |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Multiphase radiation in CFX | Luk_Fiz | CFX | 5 | March 17, 2009 03:51 |
