Can CFX treat anisotropic porous media?
Old   December 11, 2001, 17:29
Default Can CFX treat anisotropic porous media?
beginer
hello every one! The porous media I study is anisotropic porous media.The velocity of flow will change differently with different direction or even position changing. Can I change the porosity or body force with direction or make a relationship of porosity or body force and position in CFX?
Old   December 21, 2001, 09:37
Default Re: Can CFX treat anisotropic porous media?
Fred
Hello
I use CFX4.3. I don't know if the new releases 4.4 or 4.5 are able to treat anisotropic porous media; 4.3 didn't. But you can treat this problem, with adding a body force. To this aim, you can use USRBF (chapter 10.7 of solver manual). The problem is the body force value.
You also have to choose the right RhieChow algorithm options because it has some problem with large body force value.
Good luck
Fred
Old   May 8, 2013, 02:10
hadi
hadi.iraji is on a distinguished road
ANSYS CFX presently allows only K(permeability) to be isotropic ( Ansys CFX help)
hadi.iraji is offline   Reply With Quote
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 09:43
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 05:52
BIG TROUBLE with heat exchanger and porous media!! Andrea FLUENT 0 February 20, 2005 07:49
CFX and Reacting Porous Media Greg Perkins CFX 1 June 19, 2000 10:33
