Where is silicon in the CFX material library
Old   May 8, 2013, 10:10
Question Where is silicon in the CFX material library
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Where is silicon in the CFX material library?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   May 8, 2013, 11:42
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
If a material is not available in CFX you need to create a new material and define its properties.
JuPa is offline   Reply With Quote
Old   May 8, 2013, 11:54
Question
Anna Tian's Avatar
Meimei Wang
How to check whether it is available or not? There are a lot of libraries in CFX.
If none of the CFX libraries contain the property of silicon, then I shall look for international standard temperature dependent property of silicon at which website?
Best regards,
Meimei
Old   May 8, 2013, 14:34
OJ
oj.bulmer will become famous soon enough
Right click on Material >> Open the library
You will see an option to select different library ccl's in CFX
A quick search there told me that of all the libraries CFX has (some 15 odd), none has Silicon, neither does FLUENT.
You can try some sites for the properties. How about matweb.com etc? They are quite resourceful.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 10, 2013, 13:57
Erik
evcelica is on a distinguished road
Silicon Properties:
http://www.virginiasemi.com/pdf/Basi...%20Silicon.pdf
Should work now, I don't know why it put a space in there the first time?
evcelica is offline   Reply With Quote
Old   May 10, 2013, 14:39
Anna Tian's Avatar
Meimei Wang
Originally Posted by evcelica View Post
Silicon Properties:
http://www.virginiasemi.com/pdf/Basic%20Mechanical%20and%20Thermal%20Properties%20 of%20Silicon.pdf
That page can not be found.
Best regards,
Meimei
Old   May 10, 2013, 16:20
JuPa's Avatar
Mr CFD
Hint: URL's don't have spaces.
[Other] Multi species mass transport library [update] novyno OpenFOAM Community Contributions 111 November 9, 2021 23:37
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 08:00
Access Material library in UDF icemesh Fluent UDF and Scheme Programming 2 April 18, 2013 07:53
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
