Boundary condition for solid region at inlet
Old   May 15, 2013, 02:49
Default Boundary condition for solid region at inlet
Karthik
selvam2487 is on a distinguished road
Send a message via Skype™ to selvam2487
Dear Friends,
I am currently performing Large Eddy Simulation of thermal mixing of fluid flows in a T junction piping system. I am a litte bit confused as to what boundary should I give for my solid region present at the hot and cold inlets of piping system(See the figures attached). Since the solid and the fluid regions are continuous and not exposed to atmosphere, what would be the suitable boundary condition for the solid region present at the inlet? It may sound like a basic question, but I am a bit confused in which boundary conditions to apply and any help in making my understanding of the concepts better would be appreciated. Thank you.
Regards,
Karthick
selvam2487 is offline   Reply With Quote
Old   May 15, 2013, 03:21
You should match whatever you are modelling. If it goes to a big block of material which is at constant temeprature then use a constant temperature. If it is a convective boundary with air then use that. If it has no heat transfer use adiabatic.
boundary conditions, mixing of fluids, t junction
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
