Eddy viscosity ratio to get the boundary layer thickness
Old   May 28, 2013, 09:23
Question Eddy viscosity ratio to get the boundary layer thickness
Francesco
Cecco is on a distinguished road
I have simulated the flow into a centrifugal fan.
Now I have plotted the Eddy viscosity ratio (Eddy viscocity/dynamic viscosity) in order to get the thickness of the boundary layer (see the figure).
I surprised to watch that the EVR increase also outside the boundary layer.
I was expecting to see EVR=0 adjacent to the blade, then an increasing inside the boundary layer and then again EVR=0 ouside the boundary layer.
Is it strange? What do you think about? This would be that between two blades the flow is a continuing mixing?
Thanks in advance
Cecco is offline   Reply With Quote
Old   May 28, 2013, 10:29
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
Curious: what value of eddy viscosity ratio will give you the thickness of the boundary layer?
The eddy viscosity ratio is simply the ratio of turbulent to laminar (molecular) viscosity. If you have values of eddy viscosity ratio outside of your boundary layer then it just indicates some sort of laminar or turbulent regime.
To be honest I don't see why this is strange.
JuPa is offline   Reply With Quote
Old   May 28, 2013, 10:41
Lance
Lance is on a distinguished road
As far as I know the eddy viscosity ratio should have its maxium value close to the middle of the boundary layer, at least for external flows. In the free stream the eddy viscosity is governed by the turbulence at the inlet, but it shouldnt necessarly be zero.
Also, your color range is [0,1] which is normally too low for RANS models. Try something on the order of [0,100] or more.
Lance is offline   Reply With Quote
Old   May 28, 2013, 11:17
Francesco
@ RicochetJ:
I expected to see the same of this one: http://www.computationalfluiddynamic.../2013/04/2.png
probably it means this is laminar outside boundary layer, while mine is turbulent so explain the ratio doesn't come back to zero outside.
@Lance:
You can see image below with EVR btw [0;70]. I plotted [0;1] just to underline the bondary layer.
Thanks guys.
I have no much experience in internal flows. Do you think it is a normal way to work (i mean in a turbulent regime) for a tangential blower (max volume flow rate 70 m3/h)?
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Wall coordinates and boundary layer thickness bentmol Main CFD Forum 1 July 3, 2011 20:44
Question about eddy viscosity ratio limit Piti CFX 2 January 17, 2008 16:49
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 21:28
