SST turbulence with Gamma theta and Boussinesq model |
June 10, 2013, 10:16 |
Govindaraju
Rep Power: 17 |
Dear all
I am doing heat transfer problem. The flow is horizontal ( Z direction) and pulsatile in nature. If I turned on the buoyancy option, what is happening in the heat transfer? ( I believe that cfx solver solves convection heat transfer) (Also please clarify in my case what shall I put the values in gravity x direction , y direction and z direction?( I am thinking to put z direction gravity =0 and I don't know y and x direction components? I am so confusing x directional gravity -9.8m/s^2 or y component gravity -9.8 m/s^2). If I turned off buoyancy, what is happening in the heat transfer? ( is it conduction heat transfer? ) |
June 10, 2013, 22:17 |
Rep Power: 143 |
Yes, CFX solves convection heat transfer.
Convection heat transfer is of two main forms: Natural convection where the flow is being driven by the density difference in the flow - you need gravity turned on to model this, and a fluid where density is a function of temperature (or a body force in proportion to temperature). Forced convection is where an externally driven flow causes heated fluid to be removed from a hot surface - you do not need gravity for this convection heat transfer. |
June 11, 2013, 00:46 |
#3 | |
Govindaraju
Rep Power: 17 |
Thank you so much Is the CHT availbale in the tutorial convection heat transfer? Thank you |
