Variable Heat capacity of solid particles
Old   July 12, 2013, 05:09
Default Variable Heat capacity of solid particles
S.F
prX411 is on a distinguished road
Hi Guys!
I am running a steady state simulation in CFX 14.0 of a free jet in which solid particles are injected. The model uses the Particle Transport Solid i.e Eulerian-Lagrange model which works since my particle volume fraction is low in the whole domain (less than 0.005).
The results are ok but so far i have just analysed the results for differents meshs...for that purpose i chose a constant value for the heat capacity of the particles. Since I have found the mesh now that is fine enough I now want to improve the particle properties of the solid particles.
Now i tried to different ways to add a temperature dependent behaviour for the heat capacity of the particles: An expression that was fittet to experimental results as well as an user function with interpolation data.
In both cases the solver returns an error at the beginning that only Nasa Polynomials, Zero pressure Polynomials or canstant values are allowed:
After I read the manual about these polynomials I think this is no solution for me since i have solid particles --> no gas constant
Does CFX just "acts" like there is a gas constant for the solid material and if yes how can i add a zero pressure polynom for my particles?
Thanks!
Regards
prX411 is offline   Reply With Quote
Old   July 12, 2013, 09:53
S.F
Ok
i added the Zero pressure polynom now to my modell...but the solver doens't start and returns an error. The Particles enter the domain with a temperature of 300 K and attain temps. over 2700 K so i choose the a range of 300 to 3000 Kelvin for particle temps.
I used excel to fit the experimental results and divided the coefficients by the specific gas constant although that doenst really exist for my solid particles.
So there is only the question left if CFX just "acts" like there is a gas constant for the solid material or not.
Does anyone know another way to fix that problem?
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Effects of specific heat capacity modification - fluid/solid mesh simplifications Martin_D Main CFD Forum 0 January 30, 2013 06:24
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Particle solid specific heat variable with temperature pantarei83 CFX 3 June 10, 2009 18:06
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
