August 10, 2020, 09:01 |
Problem with the wireframe in CFX-Post
Rep Power: 8 |
I generated an airfoil geometry in DesignModeler and solved the flow over it using CFX. In the CFD-Post I inserted a polyline in which the points are exactly the same with the ones used in DesignModeler to create the 3d curve. But, the problem is that the wireframe doesn’t match the polyline precisely and I think the polyline is the correct curve. I attach the figure to better express my point. Doesn’t the wireframe show the geometry created before? Or what’s the problem?
August 10, 2020, 09:23 |
Henrique Stel
Rep Power: 17 |
As far as I understand the Wireframe will be just a piecewise-linear interpolation of the actual mesh points located on the edges that divide faces. Thus, if it looks a "broken" curve for you, it could be because your mesh is coarse (maybe not coarse from a numerical sensitivity perspective, but actually for the graphic resolution you expect from it). I believe (really not sure) that the Polyline, on the other hand, is a spline interpolation of multiple points created by CFD Post.
August 10, 2020, 09:24 |
Gert-Jan
Rep Power: 27 |
The wireframe follows your mesh. To me, it looks like the mesh is too coarse.
(The wireframe is displayed when the angle between adjacent elements is larger than 30°. You can increase this value to e.g. 45°. Then it will display less lines. But that won't help in your case.) |
Modify SST kw model in CFX | Tingyun YIN | CFX | 6 | May 12, 2017 06:44 |
Grids problem in CFX (imported from ICEM) | Anna Tian | CFX | 10 | July 9, 2015 09:44 |
Turbine Blade Flutter additional Varialbles display error in CFX post | sagarparikh31 | CFX | 8 | January 27, 2015 07:22 |
Ansys 13 CFX problem on LInux Opensuse 11.4 | serendipity | CFX | 10 | August 7, 2012 03:24 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
