use two-dimensional solution
Like Tree1Likes
  • 1 Post By Opaque
Old   July 28, 2015, 13:06
Question use two-dimensional solution
A.heydari
heydari is on a distinguished road
Hi;
If we want to use two-dimensional solution,
1. Which thickness can be used to model (for example, thickness of model is 7.5 cm,in two-dimensional model, how much?)
2. What proportion of the input should be a discharge plan (for example, 1.5 liters per second flow rate of input, how much in two-dimensional model?)
heydari is offline   Reply With Quote
Old   July 28, 2015, 17:53
Steffen595 is on a distinguished road
trawl through the recent posts. There was something that Ansys assumes the depth with 1m
Steffen595 is offline   Reply With Quote
Old   July 28, 2015, 19:05
Q1: See FAQ: http://www.cfd-online.com/Wiki/Ansys..._simulation.3F
Q2: A 2D planar model will have a flow rate like 10 l/s per metre. In CFX as you are modelling the depth you have to scale it accordingly - so if your mesh is 0.1m thick then you would need to apply 1 l/s.
Old   July 20, 2023, 15:55
falsc233 is on a distinguished road
sorry for replying to this ages-old thread, but is there any reason why the 2D planar mesh extrusion thickness should be about the same as the element edge length? I understand this is the recommendation from the solver modeling guide, but since the front and back surfaces are both symmetry, would the thickness matter at all? I'm asking because when I change the extrusion thickness in a 1D conduction model, the exiting heat flux do show a small variation which I was not expecting.
falsc233 is offline   Reply With Quote
Old   July 20, 2023, 16:45
Opaque will become famous soon enough
If you are running double precision, and reasonable aspect ratio for the mesh it should not matter.
However, if the planes are too far apart, high aspect ratio and single precision, you must recall that Ansys CFX is vertex based; therefore, there are two solution fields on each symmetry plane and because a solution algorithm is not perfectly symmetric, you may get into spurious iterations and it may take longer to converge.
Ashkan Kashani likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Asymmetrical solution using RANS Marli FLUENT 2 January 9, 2015 09:26
Solution Diverging with Trimmer Mesh rietuk STAR-CCM+ 8 February 27, 2013 04:50
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 15:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 12:05
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
