first mesh hight must be higher or boundry layer??
Old   August 23, 2013, 13:46
Default first mesh hight must be higher or boundry layer??
mohammad
mshf7 is on a distinguished road
hi
I am modeling a ship hull.when I am meshing and using boundry layer around the hull, the amount of total thickness of boundry layer must be more or the hight of first tetra mesh which I use?I mean the total thickness of boundry layer hight should fill first mesh hight or reverse vica?
thank you so much
mshf7 is offline   Reply With Quote
Old   August 23, 2013, 17:46
Bruno
brunoc is on a distinguished road
From what I understand from your question, you're asking if the total boundary layer element height should be equal to tetra sizes. If that is the question, then generally, no.
You should calculate the height of the first element according to the y+ required by your turbulence model. Then choose an appropriate growth rate (will vary between 1.05 and 1.3, you might need to do a sensitivity analysis here) and last, choose a number of layers such that the volume ratio between the last BL element and the first tetra is around 0.7 - 0.9.
That means in most cases the total height from the elements in your BL will be 2-5 times the local tetra size.
brunoc is offline   Reply With Quote
Old   August 24, 2013, 08:19
Default hi
mohammad
thank you dear brunoc
you got my question right.there is a problem when I obey these rules and meshing, the aspect retio would increase very much and some warnings appearance.also I cannot decrease the tetra size so much in orther to be 2-5 times lower than B.L element.
thank you
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
