Negative Total Pressure Loss Coefficient near the casing in axial compressor |
August 24, 2013, 08:23 |
AGNIMITRA
Hi!
My question is specific to CFX Turbomachinery, axial flow compressor. I am trying to plot the circumferentially averaged value of total pressure loss (occurred between the stator inlet and stator outlet stations) along the annulus height (from Hub to casing),i.e along the hub to shroud line. Total Pressure Loss Coefficient= (P03-P02)/(rho*V^2); But i find that very near to the casing i.e. at nearly 99.5% of annulus height, i find an increase in pressure or a small negative pressure loss coefficient,which means energy is being created,which does not happen within a stator passage.Does it mean that theres an energy transfer/migration from somewhere to the viscous layer nearby the casing region? I donot know how to explain the negative number(rise in total pressure at a single point in the viscous region).The entropy rise is positive at that location , obeying thermodynamics well Please ,if any one has any idea of where i am going wrong,let me know. |
December 15, 2017, 22:34 |
Suryansh
Hi, I am also facing a similar problem at rotor hub, the loss coefficient is coming negative from 0 to .15 span. were you able to find any solution to your problem?
loss coefficient, negative total pressure |
Total pressure loss | Shljuki | CFX | 9 | June 13, 2013 07:41 |
Velocity profile disturbance due to loss coefficient | rks171 | Main CFD Forum | 3 | May 25, 2012 17:30 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
