time-averaged velocity
Old   September 4, 2013, 09:19
Smile time-averaged velocity
Jerrica Lee
Jerrica is on a distinguished road
I'm modeling a transient case, how can I get time-averaged velocity in CFX Post, that is to say to average the velocity of several timesteps. Thank you in advance
Jerrica is offline   Reply With Quote
Old   September 6, 2013, 10:10
Erik
evcelica is on a distinguished road
You could output the transient results yourself using the chart option. Then average them yourself in excel or some other software.
evcelica is offline   Reply With Quote
Old   September 6, 2013, 10:46
Bruno
brunoc is on a distinguished road
If you're talking about the velocity field for the entire domain, there are ways to do that, but they need so much work that they're not even worth talking about.
What you should do is go back to your setup and, on Output Control, create a new 'Transient Average' object. In there you can set a time averaged variable for velocity (and/or for each velocity component). Unfortunately this involves re-running your simulation.
If it's only for some points/regions of your domain, you can do what Erik mentioned, but you'll be limited to the frequency used to export the transient files. Next time, use a monitor point to export the data from every timestep.
brunoc is offline   Reply With Quote
Old   September 6, 2013, 19:12
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
I agree with brunoc. As a conservative measure I always turn on transient average statistics of essential variables. Obviously if I want to monitor a specific transient average variable which isn't in the standard list then I include it in the additional variables list.
JuPa is offline   Reply With Quote
Old   September 9, 2013, 06:32
Jerrica Lee
well, it seems that the huge work load involved would make me crazy! But thank you all the same
Old   September 9, 2013, 06:35
Jerrica Lee
Thank you for your suggestion. But I'm wondering how to create a new 'Transient Average' object on Output Control, can you show me more details?
Old   September 9, 2013, 06:42
Lance
Lance is on a distinguished road
Double click on Output control
Click on Trn Stats tab
Click on "Add new item" icon
Click on OK
Check that Option: Arithmetic Average
Check that Output Variables List: Velocity
Click on OK
Do you need more detailed instructions?
Lance is offline   Reply With Quote
Old   September 10, 2013, 04:36
Jerrica Lee
Oh I got it, thank you so much
time-averaged
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
