Exporting and Importing CFX files to run on a HPC |
July 16, 2020, 10:34 |
Thu Win
Rep Power: 9 |
My University has an HPC but sadly their technical support is a bit abysmal. This is my first time using an HPC and they told me that they can't offer me one to one help.
I would like to know:
I am assuming I need just the .def file? And the HPC will produce a result file? How do I need to import that result file? |
July 16, 2020, 11:16 |
Henrique Stel
Rep Power: 17 |
Maybe your question doesn't have much relation with the HPC itself but actually reading CFX files in a LINUX platform. Is that your doubt?
Anyway, CFX runs the exact same file extensions in Windows or LINUX. This means that, a def file you save in a Windows PC will work fine in the CFX Solver installed in LINUX, and the results file saved in LINUX can be opened in the Windows CFD Post. You may have compatibility issues if the ANSYS versions on both platforms are not the same, but still that would be only because of the software version, not because of compatibility between the platforms themselves. |
July 16, 2020, 11:23 |
Thu Win
Rep Power: 9 |
Well I don't know what files do I need to copy over to the HPC.
And how to merge back the results? Do I just copy it back to the same folder? |
July 16, 2020, 12:54 |
#4 | |
Henrique Stel
Rep Power: 17 |
If your run depends on a initial values file, copy the .res file you want to use to initialize your case together with your def file to the HPC as you are going to need it in the runtime. |
July 16, 2020, 12:56 |
Thu Win
Rep Power: 9 |
What do you mean by initial values? Like inlet speed?
Also, how do you export a def file? I can't find a setting to export it. |
July 16, 2020, 13:04 |
Henrique Stel
Rep Power: 17 |
Hmmm... How familiar are you with ANSYS? Maybe you should have a look first in ANSYS CFX Tutorials, especially the first ones explaining how to use CFX in Standalone mode.
July 16, 2020, 13:09 |
Thu Win
Rep Power: 9 |
I have used CFX on my own computer and not using a HPC server.
I have tried googling but couldn't find anything relevant. If you have a good reference, can you link it here? |
July 16, 2020, 13:18 |
Thu Win
Rep Power: 9 |
Edit: It seems that the .def file is in the dp0/CFX folder since I used Workbench to set up the experiment.
July 16, 2020, 14:35 |
#9 | |
Henrique Stel
Rep Power: 17 |
If that is the case, it will depend on how the HPC is configured in your University, but usually, you'll not be able to do that. That's why I was telling you to use CFX in Standalone mode. Standalone mode means "using CFX as a separate software, without Workbench". The second CFX Tutorial provided in the ANSYS Portal teaches you how to do that. This way, you will prepare your case in your PC as usual using CFX Pre, save a def file (see the Tutorials to learn how to do that), and then you will copy the def file to your working folder to the HPC. Then open the CFX Solver in the HPC, open the def file there and solve your problem. A .res will be generated when the job is finished. Use the Standalone version of CFD Post to post process it (see the Tutorials to learn how to do that!). Another way is to do your entire Workbench job directly on the HPC. Most server administrators won't let you to do that, but you will have to check that yourself. Try talking to someone who have used ANSYS in the HPC from your university in the past and ask them how they managed it. |
Error when exporting 3D mesh from pointwise to cfx | razally | CFX | 4 | November 20, 2015 19:37 |
[CAD formats] Importing mesh files to OpenFOAM: is obj format viable? | sudo | OpenFOAM Meshing & Mesh Conversion | 3 | March 5, 2014 05:14 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
problem with importing and exporting profile BC | Gui | CFX | 2 | July 26, 2007 08:50 |
Problems with exporting and importing CAS files .. | Danny | FLUENT | 0 | September 16, 2005 10:47 |
