Timescale vs Iteration loops for Transient Turbomachinery |
October 17, 2013, 11:52 |
Rep Power: 15 |
I am running a transient turbomachinery model with a stator followed by a rotor. I have been slowly decreasing the Timestep and increasing the number of coefficient loops to achieve convergence, but am still not sure that I am getting convergence. If I switch on "Monitor Coefficient Loop Convergence" and watch a key parameter such as pressure rise over the system, I would expect that an indication that I have adequate timestep size and sufficient coefficient loops would be if at the end of each timestep, the pressure rise is not changing from one coefficient loop to the next. Am I correct in assuming that the above is an important indicator to watch for? I think I have an adequately small timestep (Max courant # < 10 and TS ~= 1/1600th of a revolution for a 4 bladed device), but yet when I look at the convergence of each timestep individually, the pressure rise across the pump is not steady even after 15+ coefficient loops where the RMS of the residuals has reached ~1e-8. If anyone knows any sources for guidelines for TRANSIENT turbomachinery convergence, I would appreciate it. It is not covered in either the turbomachinery best practices guide (http://www.cfd-online.com/Wiki/Best_...omachinery_CFD) or the standard convergence criteria documentation. Thanks in advance, Saleh |
October 17, 2013, 11:54 |
Rep Power: 15 |
I guess a follow up to that question is, if I am NOT satisfied with convergence, is there a way to know whether the culprit is because I have too large of a timestep OR because I don't have enough coefficient loops...
October 20, 2013, 19:59 |
#3 | |
Rep Power: 143 |
The way to check all the parameters you mention (convergence, timestep, coeff loops) is to do a sensitivity check on them. Sweep over a range of values and see if the result changes. And don't forget convergence and coeff loops are just different ways of expressing the same thing. So they reduce to a single factor as they are coupled. That means a single sensitivity analysis covers both these issues. |
cfx, convergence, transient, turbomachinery |
Coefficient loops vs physical timescale | Turbomachine | CFX | 3 | February 13, 2011 19:36 |
Loops per iteration | Anon | CFX | 3 | December 11, 2007 16:29 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 22:30 |
5.7.1 solver doing max coeff loops. | Stevie Wonder | CFX | 5 | July 5, 2005 12:31 |
Heat exchanger problem | chiseung | FLUENT | 16 | October 20, 2001 04:36 |
