October 30, 2013, 01:27 |
actuator disk as momentum source
liladhar
Rep Power: 14 |
Dear all
i am trying to model propeller behind the hull as an actuator disk. For this i am modelling the disk as a momentum source. I have created the subdomain which contain the disk. The momentum per unit volume (a constant value for a moment) is given as input in x-dir. The streamline pattern obtained is very unusual. please do suggest the modifications. i have given a loss model also. In that permeability is on and area of the disk has been assigned. i have attached the streamline pattern. please help me. |
October 30, 2013, 05:06 |
Rep Power: 143 |
First of all - please do not duplicate post. I have removed the duplicate.
This looks to me like the flow has not fully developed yet. If this is a steady state model then you need to run longer to obtain convergence, if this is transient then you need to run more time steps to get the flow to develop. |
actuator disk, momentum source |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
Mass source, Momentum source theory. | diffo | FLUENT | 4 | August 21, 2009 10:26 |
Problem with Mass source, Momentum source theory | diffo | Fluent UDF and Scheme Programming | 0 | August 20, 2009 06:10 |
