Setting different diffusivities for two domains (fluid+porous) |
November 25, 2014, 13:14 |
Leonardo
Rep Power: 11 |
Hi there,
I need some help setting up a CEL expression to define different values of kinematic diffusivity for two different domains: a fluid and a porous domain. I'm aware you can use the inside() function, but I'm not sure how to write it. I tried the script below but it didn't work. 1.58e-5 [cm^2 s^-1] * inside()@flow; 0.46*1.58e-5 [cm^2 s^-1] * inside()@porous Thanks in advance. |
November 25, 2014, 14:45 |
Rep Power: 32 |
I assume you are defining the Kinematic Diffusivity parameter for an Additional Variable, or mass fraction Component
Kinematic Diffusivity = 1.58e-5 [cm^2 s^-1] * ( inside()@flow + 0.46 * inside()@porous) That is all you need to do. I wonder what the 0.46 means. It is not the volume porosity, is it ? |
November 25, 2014, 14:48 |
#3 | |
Leonardo
Rep Power: 11 |
What is the meaning of the asterisk symbol in the CEL syntax? I did a quick check on the documentation and couldn't find much about syntax. And no, it's just the "correction" factor for the permeability at the porous media. |
November 25, 2014, 15:26 |
Rep Power: 32 |
* is for multiplication between two terms in the expression.
Not sure I catch on the "correction factor" for the permeability. There is no permeability in the diffusion terms of the transport equations I have seen. I have only seen the permeability in the drag force term in the momentum equation.. Did you mean porosity ? The only time I have seen permeability into a transport equation is when Darcy's law is substituted into the continuity equation, and a pure diffusion equation for Pressure is obtained. Is that what you are solving for ? |
November 25, 2014, 15:30 |
#5 | |
Leonardo
Rep Power: 11 |
According to the paper I'm basing my simulations on, they estimate the effective diffusivity of ethanol in the porous media using this factor, which indeed happens to include the porosity: D_eff = (porosity)^1.5*D |
cel expression, diffusivity, kinematic diffusivity, porous |
thermal couple boundary condition between porous and fluid regions | atoof | OpenFOAM Programming & Development | 2 | June 7, 2017 19:44 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
Different diffusivity for additional variable in Fluid and porous domain | ftab | CFX | 4 | June 27, 2012 13:03 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
