Transient water spray in air with droplet distribution as input
Old   April 14, 2017, 09:17
Smile Transient water spray in air with droplet distribution as input
kar.coep is on a distinguished road
I am trying to simulate transient water spray (able to be evaporated) in high temp air.
I think droplets(Phase change) is the right morphology to select. But I cannot figure out where to specify these inputs
1. Water is not injected at inlet boundary. I have a created a named selection in design modeler. Where do I specify this injection point?
2.I need to specify water injection mass flow rate, injection velocity, droplet diameter distribution, injection method as cone and cone angle value
Also I need to specify the timesteps to run this analysis and need to get output of % evaporation, wall film mass and uniformity of the liquid+vapor across the outlet face.
Any ideas on how to give inputs and generate outputs would really help.
Thank you.
kar.coep is offline   Reply With Quote
cfx, droplet phase change, evaporate droplets, transient spray
compressibleInterFoam case – a flat wall air cavity filling up with water Zeppo OpenFOAM Running, Solving & CFD 0 October 3, 2015 10:01
air into box filled with water, outflow for water at bottom dieterdanger Fluent Multiphase 0 July 16, 2015 16:11
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 08:57
A question (water droplet) john Main CFD Forum 1 October 25, 2008 03:42
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
