Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks
Old   August 13, 2009, 22:09
Default Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks
Ahmad Kermani
ahmadkermani is on a distinguished road
I am doing FSI simulation of valve and at some point CFX can not move the mesh any more and I receive negative element error.
I was thinking of re-meshing and interpolating the old results into the new mesh and go on but to do this I have be able export the deformed structure to the CAD software.
Does anybody know how I can export a deformed geometry to CAD program (for example solidworks)?
The simplest way could be creating an IGES file but I don't know how to make it.
I appreciate your help.
Ahmad
ahmadkermani is offline   Reply With Quote
Old   August 16, 2009, 02:56
Basavaraj
basavaraj.pyati is on a distinguished road
Question is bit confusing,whether you want to export from post/pre or from meshing softwares.
Its possible only in meshing software where you can export to IGES format..
I feel you may be doing transient simulation in CFX,If that is the case to avoid this you can do following things,
1) mentain uniform mesh size at stationary and moving domain(Preferably hex mesh)
2) Set expert parameters like "Check isolated regions to false"
3) Your time step value (Very important)
basavaraj.pyati is offline   Reply With Quote
Old   August 17, 2009, 17:12
Ahmad Kermani
To make my question clear, you know that one of the major problems in FSI is
mesh being folded (resulting negative element error) when the CFX is not able
to move the mesh anymore. One solution I thought is extracting the deformed
geometry of the structure at the point when the CFX can not move the mesh,
remesh it, interpolate the solution of into the new mesh and go on with FSI
analysis with new mesh.
Now the only way you can remesh the deformed domain is to have it
in a format (for example IGES) which you can open it in the CAD or mesh generator.
Simply I would like to exprot the deformed geometry from CFX-Post to my mesh generator.
Thank you for your help.
Ahmad
Old   March 3, 2016, 07:24
Wil
ikpekho2 is on a distinguished road
Hi Ahmed,
Please I was wondering if you found the solution to your problem as I have a very similar problem.
Cheers.
ikpekho2 is offline   Reply With Quote
Old   March 3, 2016, 07:26
Wil
Originally Posted by ikpekho2 View Post
Hi Ahmed,
Cheers.
Hi Ahmed,
Cheers.
Old   March 7, 2016, 10:13
cfd seeker is on a distinguished road
Hi
I have not done any problem of such kind in CFX but I don't think it's possible because CFX is solving the mesh not the Geometry. It is the mesh from Meshing Software( like ICEM CFD) which we export for solution, not the geometry...isn't it?
cfd seeker is offline   Reply With Quote
Old   March 8, 2016, 03:29
Thomas
tomson199 is on a distinguished road
You can convert mesh to parasolid file in FE Modeler. Drag the solution from static/transient structural to FE Modeler. In this link you've got an explanation how to make it:
https://caeai.com/sites/default/file...0Workbench.pdf
It's very simple.
Best regards
tomson199 is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Patch mesh export ariorus OpenFOAM 3 March 7, 2006 05:41
Gambit mesh export Satya Main CFD Forum 1 May 26, 2004 17:06
DEFORMED MESH FOR WIND-SAIL INTERACTION Javier Main CFD Forum 0 March 10, 2004 13:30
