create a chart using ansys CFX to analyze flow characteristics
Old   January 18, 2014, 01:07
Default create a chart using ansys CFX to analyze flow characteristics
shakey
shakey is on a distinguished road
i have designed a cylinder tube with length of 120mm and diameter of 3mm. There is a rectangle restriction with height of 1mm at the distance of 60mm from the inlet. I have completed untill cfx-solver step. however i am confused on how to create a chart for example to analyze velocity distribution after the restriction (70mm from the inlet). I have tried to follow guidelines from the ansys tutorial but still failed to do so. Can someone advice the correct method to generate the chart? TQ
shakey is offline   Reply With Quote
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
ANSYS CFX: Produce swirling flow using cylindrical components neilduffy1024 CFX 4 August 7, 2013 08:00
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
