January 27, 2014, 10:02 |
2D Airfoil Problems
Rep Power: 12 |
I am trying to run a supposedly very simple 2D simulation of a propeller blade. Basically it is a 2D airfoil simulation using water instead of air. Its a steady simulation in CFX. Here is some relevant data: RE:3*10^6 first cell size: 0.0005 --- corresponding Y+ values vary on the airfoil surface from 10 to 80 SST turb. Model used I am trying to verify my simulation by comparing results for a NACA1408 shape to experimental data. At 8 deg angle of attack experimental data gives a lift coefficient of 0.95, my simulation says 0.86. Does anyone have ideas how to approach this problem ? I tried: -changing mesh resolution; general resolution -changing first cell size -changing "time step" I do see a disruption of e.g. velocity profiles at a GGI interface i am using but i dont think this should affect the lift coefficient too much. Mesh resolution at both sides of the interace is quite similar too. Furthermore I have some questions about CFX which are secondary but if anyone is willing to it would be nice to have them answered - ANSYS documentation talks about a "pseudo timestep" when doing steady simulations; I dont really get the explanation though, so if anyone could explain this "pseudo timestep" it would be really nice ####ANSYS doc: CFX applies a false timestep as a means of underrelaxing the equations -> The timestep determines to what extend under relaxation is done ? -> Why not just set a under relaxation factor then ? Thanks a lot for all answers in advance Regards, Tobias |
January 27, 2014, 17:04 |
Rep Power: 143 |
This is an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Translation of an airfoil | Phil_QM | FLUENT | 4 | November 7, 2011 16:03 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
getting airfoil surface to be recongized for tri mesh | josip76 | ANSYS Meshing & Geometry | 4 | June 9, 2011 22:48 |
[ICEM] Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil | josip76 | ANSYS Meshing & Geometry | 2 | June 4, 2011 18:03 |
