April 8, 2009, 08:34 |
reflected shock in a shock-tube
mathias kiesel
Rep Power: 17 |
hello,
i'm working with ansys-cfx since few weeks and i try to simulate the pressure-distribution in a shock-tube after the origin shock and the second, wall-reflected, shock. During i'm satisfied with the calculated pressure-values after the first shock, the pressure-distribution after the reflected shock shows bad-damped oscillations i can't avoid. do you have any hints how i can improve my simulation? thanks |
April 8, 2009, 20:33 |
Rep Power: 143 |
Avoiding oscillations in shock waves is a difficult issue. I assume you are using the high-res differencing scheme? That should minimise the oscillations but still give you second order accuracy in most regions of the flow. Also what time differencing scheme are you using? Glenn Horrocks |
April 9, 2009, 10:07 |
mathias kiesel
Rep Power: 17 |
Hi glenn,
in my very first calculations i used second-order-euler-equations with a high-res-scheme. I got very bad oscillations behind my first shock. Changing to first order in euler equations improved the results for the first shock but with still unacceptable oscillations behind the reflected shock. Changing between high-res and upwind-scheme didn't change the results very much while using first-order-euler thanks for your answer matt |
April 9, 2009, 10:18 |
Rep Power: 17 |
Try switching on "high speed numerics" in the advanced panel of the solver control. This enables some numerical techniques specifically aimed at dealing with shock oscillations/instabilities (such as the carbuncle effect).
April 9, 2009, 12:13 |
mathias kiesel
Rep Power: 17 |
Hi timon,
thank you for the hint. I will try it soon and report then about my results. thanks |
January 24, 2013, 20:15 |
Shock tube simulation
cfd
Rep Power: 14 |
I am new user of cfx and I want to simulate shocktube with two different gases, Is there any body could help me in defining the two different component of fluid which I have to use in this simulation? Regards Thanks |
February 4, 2014, 17:43 |
Ehsan
Rep Power: 26 |
Hi
a question: does the flow behind the reflected shock wave have a total pressure bigger than the original driver gas? is it correct?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
Shock tube simulation | harish | FLUENT | 5 | January 25, 2014 02:20 |
shock tube validation | AB | Main CFD Forum | 3 | December 10, 2004 07:31 |
shock tube validation | AB | Siemens | 0 | November 21, 2004 18:43 |
Shock tube problem | AB | Siemens | 1 | November 9, 2004 00:25 |
