b.cs
Old   February 10, 2014, 05:02
Default b.cs
mina
mina.p is on a distinguished road
hi
i want to simulate the heat transfer & pressure drop in a channel with the blade at inlet.
can anyone help me in choosing outlet b.c?? wich one is the best for this problem?is mass flow rate a good one??
i set the inlet b.c:normal speed & walls:temperature
mina.p is offline   Reply With Quote
Old   February 10, 2014, 05:57
The documentation has a section which goes into selection of boundary conditions in some detail. It is well worth reading.
Other than that - you select the boundary condition to match what you are modelling. If it is flow controlled you use a flow boundary condition, if it is pressure controlled you use a pressure boundary condition.
[swak4Foam] and accessing flux on remote patches for setting B.C's mayank.dce2k7 OpenFOAM Community Contributions 19 August 21, 2013 19:01
B.Cs jiko FLOW-3D 1 October 23, 2010 15:09
B.C's for external body aerodynamics Rahul FLUENT 4 February 20, 2006 09:32
wall b.c's eric FLUENT 5 October 15, 2003 23:59
Applying Symmetry B.C's Short Phoenics 2 September 29, 2001 23:30
