February 10, 2014, 05:02 |
b.cs
mina
Rep Power: 12 |
hi
i want to simulate the heat transfer & pressure drop in a channel with the blade at inlet. can anyone help me in choosing outlet b.c?? wich one is the best for this problem?is mass flow rate a good one?? i set the inlet b.c:normal speed & walls:temperature |
February 10, 2014, 05:57 |
Rep Power: 143 |
The documentation has a section which goes into selection of boundary conditions in some detail. It is well worth reading.
Other than that - you select the boundary condition to match what you are modelling. If it is flow controlled you use a flow boundary condition, if it is pressure controlled you use a pressure boundary condition. |
[swak4Foam] and accessing flux on remote patches for setting B.C's | mayank.dce2k7 | OpenFOAM Community Contributions | 19 | August 21, 2013 19:01 |
B.Cs | jiko | FLOW-3D | 1 | October 23, 2010 15:09 |
B.C's for external body aerodynamics | Rahul | FLUENT | 4 | February 20, 2006 09:32 |
wall b.c's | eric | FLUENT | 5 | October 15, 2003 23:59 |
Applying Symmetry B.C's | Short | Phoenics | 2 | September 29, 2001 23:30 |
