how to analysis double pipe heat exchanger in cfx
Like Tree3Likes
  • 1 Post By gullapallivijay
  • 1 Post By ghorrocks
Old   May 12, 2011, 14:25
Post how to analysis double pipe heat exchanger in cfx
Ram krishna shah
rammax8 is on a distinguished road
Send a message via Yahoo to rammax8
hii friends,
i'm ram krishna.i have taken final year project to simulate a double pipe heat exchanger but i don't know how to do it.can some one tell me step by step procedure to simulate a double pipe heat exchanger in ansys cfx.
i want to know everything from mess generation to defining inlet, outlet, how to set fluid properties and how to give domain interface. i have to finish my project by 30 may so some one please help me. i will be very grateful to you.
thank you very much
rammax8 is offline   Reply With Quote
Old   May 13, 2011, 02:34
Lance
Lance is on a distinguished road
No one is going to write a step-by-step tutorial for you, especially if you have no prior knowledge about CFX. I suggest that you do a lot of tutorials to familiarize yourself with the program. Have a look at tutorial 16 which deals with heat transfer from a heating coil.
Lance is offline   Reply With Quote
Old   May 13, 2011, 05:31
Default is their any book available which has step by step procedure to work on heat exchange
Ram krishna shah
hii friend,
thank you for your concern. is their any book available from where i can learn the procedure of analyzing heat exchangers in cfx or fluent.
Old   May 13, 2011, 05:51
Lance
I haven't seen a dedicated CFX book on heat exchangers, that's why I said that you should look into tutorial 16. The manual will also be useful.
Old   May 16, 2011, 06:12
Vijaya Sekhar Gullapalli
gullapallivijay is on a distinguished road
You might need to perform conjugate heat transfer for double pipe heat exchanger. Moreover, proper near wall resolution is necessary. Meshing for the solid domain can be tricky due to large aspect ratio and you might need to have a number of cell layers (something like 4-5) in pipe domain. k-w SST model is recommended when you have separated flows etc.
davidrlc89 likes this.
gullapallivijay is offline   Reply With Quote
Old   May 16, 2011, 18:55
If the solid wall is thin you can use the new capability (V13 I think) to put a thin interface between two fluid regions. This way you do not mesh the thin solid layer, but replace it with a representative thermal resistance. This may simplify things for you.
amin_gls likes this.
Old   May 17, 2011, 03:39
Agree with ghorrocks. Thin interface is possible. But sometimes, pipe features enhance or deter local heat transfer and temperature difference. In those cases CHT is interesting for determining local distribution of wall temperatures and heat flux for pipe domain and wall heat transfer coefficients etc for fluid domains
Old   May 17, 2011, 19:07
Obviously if reducing the solid down to a simple thermal resistance is not appropriate then the thin surface approach is not appropriate. Also keep in mind I do not think the thin surface takes into account the thermal mass of the solid (I think). So if you are interested in transient behaviour you will also have to determine if the solid time scale is fast enough to be ignored.
Old   May 24, 2011, 10:44
Ram krishna shah
hii vijay..thanks for your replies...but i really need help.i can't do it on my own i tried it..my last date for submission of project is 15 june.can u let me any other way to do.like step by step procedure from modelling to analyzing in any cfd software.
thanking you
regards,
ram krishna
Old   May 24, 2011, 19:13
I do not have time to write step by step procedures.
If you tell us what does not seem to be working we will try to help.
Old   March 29, 2013, 21:15
David Lopez
davidrlc89 is on a distinguished road
this is a quick way to simulate the heat transfer through the solid, and if the version 13.0.
The only problem with doing this is that you will do the transfer only in one dimension.
But it's good to start your simulation aporximacion.
regards
davidrlc89 is offline   Reply With Quote
Old   February 14, 2014, 14:49
Default interface error
  #12
hardik thakkar
hardiksam is on a distinguished road
in post processing, i m getting error related to interface...
so what parameters should i modify in order to get simulation result.
hardiksam is offline   Reply With Quote
Old   February 14, 2014, 16:10
Please start a new thread for a new question. And when you do please include enough information to make it a worthwhile question - see http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
Heat sink analysis Scott Hansen CFX 8 May 6, 2015 10:32
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 15:45
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
