Use CEL in a transient analysis to record WSS at a specific time interval
Old   February 24, 2014, 15:42
Default Use CEL in a transient analysis to record WSS at a specific time interval
Josh
Pezzzz is on a distinguished road
I running a simulation in Workbench to run a mesh independence study. I am using parametrisation and want to look at the effects of mesh on WSS at a specific point.
I know how to export the value from CFX post into the parameter set in CEL:
maxVal(wall shear)@Aneurysm
However as the simulation is transient, I would like to export the value at a specific time (0.64902s, #60).
I'm sure there is a simple function I am looking for, but I am not familiar with CEL. Any help is much appreciated.
Thanks
Pezzzz is offline   Reply With Quote
Old   February 24, 2014, 16:14
I have not done something like you request - but if you set the transient simulation up to finish at 0.64902s does the CEL function return the appropriate value?
Old   February 25, 2014, 02:29
Lance
Lance is on a distinguished road
Wouldnt maxVal be a bad choice for a mesh independence study, since the location of the maximum value might change when you refine the mesh? Why not use a bunch of monitors with fixed locations instead? In that way you will get the value at any time during the solution.
Lance is offline   Reply With Quote
Old   February 25, 2014, 06:34
Matthias Voß
mvoss is on a distinguished road
If the point of interest is known on beforehand you can use the CEL probe-function most similar to your expression and hook it up to the parameters in wb.2.0.
Just an idea: you can use a step-function in combination with the count-function to check if the WSS in a certain range changes by refining the mesh somewhere. Like said above - just to check for the maxVal isn't what you are actually looking for.
mvoss is offline   Reply With Quote
Old   February 25, 2014, 15:56
Josh
@ghorrocks, Thats I good idea, I will give this a go, don't see why it would'nt work.
@Lance, You make a good point. Is there any chance you can give me some advice, on how to find the WSS values at specific points in the mesh? Or point me to somewhere that explains how to? As I said before I have little experience of CEL.
Thanks
Old   February 25, 2014, 16:19
Josh
I have looked at probe and the format is probe(<val|expression>)@<location>.
I assume the way to reference specific points as locations is to make source points for the <location> in CFX-Pre?
Old   February 26, 2014, 04:33
Matthias Voß
You create the location in cfx post by selecting a node number or a xyz-coordinate. If you want to monitor it during solving then you have to create a monitor point in cfx pre.
cel, cfx, parameter set, transient
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 10:54
determining time step size in transient analysis aaditya27993 FLUENT 0 September 7, 2013 09:57
Determining the time step for transient analysis pintogeorge88 FLUENT 1 March 3, 2013 05:20
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
