Rendering 3d mesh onto a plane
Old   March 28, 2018, 10:38
Default Rendering 3d mesh onto a plane
Tom D
tomd97 is on a distinguished road
I'm just wondering if its possible to render a 3d mesh from a plane in ansys cfx post? Like if I render a mesh at a plane other than the domain boundaries, the mesh doesn't look as nice compared to the patch conforming at the surfaces of the domain. I want to show that this is because the mesh was rendered at any internal plane and the weird shapes seen are a result of the sectioned 3d elements which are still valid, but simply arent located at the domain boundaries.
So is it possible to render 3-dimensionally the mesh elements that are sectioned by a plane in ANSYS post? Similar to what is available in meshing.
Thanks
Tom
tomd97 is offline   Reply With Quote
Old   March 29, 2018, 08:17
urosgrivc
urosgrivc is on a distinguished road
Well the answer is ofcourse you can do that, if I understand corectly you want to see elements in 3d.
First way i can think of is ISOVOLUME rendering. You can colour the volumes acording to location like x,y or z location if value is higher or lower or imbetween values than the one you set, than those elements are shovn, you can also colour them with a wariable or smooth them if you want a more averaged nice surface
urosgrivc is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
GMSH - Very strange effect - Mesh elements deleted when saving Araist Mesh Generation & Pre-Processing 3 July 15, 2015 06:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
