March 31, 2014, 05:27 |
PC configuration
OJ
Rep Power: 20 |
I need a bit of help in deciding the configuration and correct pricing for the PC:
Quote 1: This one is with processor “Intel i7 4930K Unlocked (6 x 3.4 GHZ)” Computer Case: Black ATX Tower Case CPU: Intel i7 4930K Unlocked (6 x 3.4 GHZ) CPU Cooling: Intel Heatsink & Fan - Low Noise CPU Compound: Standard CPU Compound Supplied With Heatsink Memory: Corsair Vengeance LP 32GB 1866 MHz (4x8GB) - Lifetime Warranty (DDR3) Graphics Card: 1 x NVIDIA GeForce GTX 750 - 2GB - (EVGA) - Superclocked - (PCI-E) Power Supply: Corsair 450W PSU - Low Noise Motherboard: Asus P9X79 (Intel X79) Hard Drive #1: 1 TB Seagate (1000 GB) SATA-III HDD 7200 RPM 64MB Operating Systems: Microsoft Windows 7 Professional 64 BIT (Genuine DVD & COA Included) Monitors: 1 x 24" HD LED Widescreen Monitor - Black - 2ms - 1920x1080 - DVI/VGA PRICE: £1453 Quote 2: This one is with "Intel i7 4930K Unlocked (6 x 3.4 GHZ) OVERCLOCKED UPTO 4.4 GHZ" and as a result of this overclocking, the first three components (highlighted in red) need to be changed due to compatibility issues. Computer Case: Aerocool X-Predator X1 Devil Red CPU: Intel i7 4930K Unlocked (6 x 3.4 GHZ) OVERCLOCKED UPTO 4.4 GHZ CPU Cooling: Coolermaster Hyper 212 Evo - Low Noise CPU Compound: Standard CPU Compound Supplied With Heatsink Memory: Corsair Vengeance LP 32GB 1866 MHz (4x8GB) - Lifetime Warranty (DDR3) Graphics Card: 1 x NVIDIA GeForce GTX 750 - 2GB - (EVGA) - Superclocked - (PCI-E) Power Supply: Corsair 450W PSU - Low Noise Motherboard: Asus P9X79 (Intel X79) Hard Drive #1: 1 TB Seagate (1000 GB) SATA-III HDD 7200 RPM 64MB Operating Systems: Microsoft Windows 7 Professional 64 BIT (Genuine DVD & COA Included) Monitors: 1 x 24" HD LED Widescreen Monitor - Black - 2ms - 1920x1080 - DVI/VGA PRICE: £1558 I have two questions: 1) Is the configuration (6 cores, 32 GB RAM etc) alright to comfortably run CFX/FLUENT? It would be mostly used for porous regions, vortex shedding analysis and a multiphase simulations, covering both steady and transient simulations. 2) Is the £100 increase in configuration due to overclocking reasonable? Thanks a lot! OJ |
March 31, 2014, 16:22 |
Edmund Singer P.E.
Rep Power: 20 |
Did you look up the difference in the case and CPU cooler separetly? That is essentially what you are paying for.
The motherboard/cpu is the same in both cases, so you could overclock this yourself. But you have to worry about the cooling, which I assume they did correctly for that speed. |
March 31, 2014, 17:47 |
Rep Power: 143 |
Be aware that CFD loads the CPU very highly for long periods of time so you will be really loading this overclocked system. And it also heavily loads the memory pipeline, FSB and a few other bits of the motherboard as well. It is not just the CPU. I would not consider an overclocked system for CFD work.
Sure, you can overclock and it runs fine most of the time. But I am just thinking about having to face the CEO and say "The simulation failed and I fried the computer because I tried to squeeze a bit of overclocking out of it." It might be boring using stock computers but at least if they go wrong it is a straight-forward warranty issue. But that's just my opinion. Feel free to overclock if you feel brave |
March 31, 2014, 23:23 |
Rep Power: 18 |
Why do you need overclocked gaming graphics? IMO Quadro series is better choice. And I agree with Glenn about CPU overclocking. You'd better not overclock it and then you can buy not unlocked version which must me cheaper. Also i7 has turboboost technology so it can auto overclock if not all cores are used.
April 1, 2014, 13:16 |
#5 | |||
OJ
Rep Power: 20 |
April 2, 2014, 07:33 |
OJ
Rep Power: 20 |
Also, I was wrestling with the choice for the processor. I have read that opting for overclocked CPU versus normal unlocked CPU doesn't really add much benefit when it comes to solution times, is it true?
Also, my current configuration is 6 core processor. Would going for a standard 4 core processor (with a bit high frequency) be better? Is the performance boost going from 4 to 6 core significant? Thanks |
April 2, 2014, 07:50 |
Rep Power: 143 |
Your best bet for getting performance information on CPUs is at www.spec.org. The raw benchmark is effectively the single processor performance, and the rate is the multi-processor performance so you can work out the scaling effectiveness from that.
In most commercial license cases it makes sense to purchase a smaller number of licenses and get the fastest CPU possible - so less cores, more speed. In fact license costs usually swamps computer cost so it often makes economic sense to only use 1 or 2 cores on a PC and do distributed parallel across several PC. This was certainly the case several years ago by multicore operation has improved a lot recently and things have hopefully improved. You know what I will say about overclocking.... I have already said it. It is not worth the risk. But if you can handle a bit of risk and some simulations dying due to stage overclocking behaviour then go for it. |
April 2, 2014, 07:56 |
#8 | ||
Rep Power: 18 |
Problem with setting configuration controls | ajialiang | CFX | 0 | July 2, 2012 03:07 |
Multiple Configuration Simulation | Tristan | CFX | 0 | November 13, 2009 23:01 |
suggestion need desktop configuration for fluent | Ravinder Reddy | FLUENT | 3 | September 9, 2005 08:09 |
calculating missle configuration by panel method | Daniel | Main CFD Forum | 5 | January 6, 2003 08:09 |
airplane configuration | Shereef | Main CFD Forum | 10 | October 26, 2000 11:48 |
