CFX Solve Error in PEEKI routine
Old   April 10, 2014, 05:27
Default CFX Solve Error in PEEKI routine
Tom Elson
Tom.Elson is on a distinguished road
Have any of you guys come across this error before? I have seen a similar one on here before, and the problem was inconsistent naming of the domains. But I can't seem to find such problem in my definition file.
Details of error:-
Error detected by routine PEEKI
CDANAM = ../../ZN4 /ISUB
CRESLT = NONE
Current Directory : /FLOW/ALGORITHM/GLOBAL/SUBSYS/HYDRO_SG3/HYDRO_CM1/ZIF14
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
Previous similar issue:
http://www.cfd-online.com/Forums/cfx...ror-peeki.html
Any advice on the issue would be appreciated.
Thanks
Tom
Tom.Elson is offline   Reply With Quote
Old   April 10, 2014, 06:25
The error message does not help much, does it?
There is going to be some error in your set up. I would simplify your model to something which runs, then add the complex bits one at a time until you find the bug. It is tedious, but in this case it looks like the only way.
Old   April 10, 2014, 06:34
Tom Elson
Thanks for the advice. That's my plan.
Its a multi-component flow with gas, oil and water, two domains one with gas, and one liquid domain with oil and water as a continous fluid. I have simplified it to just be water not water and oil but no such luck.
It is probably something really stupid I am missing.
Thanks
Tom
Old   April 10, 2014, 06:43
Sounds like there is some complex physics there so plenty of stuff to go wrong. I would start with simply a simple single phase flow through the thing. Check that the mesh can actually run. Then add the multi-component and multi-phase stuff one bit at a time.
Old   April 10, 2014, 08:06
Tom Elson
Yeah, I switched the liquid domain to solid, just as a test.
I no longer get that error. Get a Chk_Splane one now due to symmetry conflict, but that should be an easy fix. Its always tempting to run complex models straight away, but it rarely works!
Thanks
Tom
PhD using CFX Rui CFX 9 May 28, 2007 05:59
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
Can CFX solve problem with structured mesh? Peted CFX 2 May 31, 2004 23:45
How to solve Poisson equation in CFX 4? windhair CFX 3 January 27, 2004 21:09
