How to import indivisual CSV file to CFX for post processing
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By Lance
Old   April 4, 2013, 05:39
Default How to import indivisual CSV file to CFX for post processing
mohammad
mohammad is on a distinguished road
Dear all,
My qusetion is this:
I have an indiviual CSV file containing "Node and Value" information. Can I use CFX-Post for postprocessing?
how?
please note that the CSV file is already created (exported) from another CFX-result file.
Thanks a lot
mohammad is offline   Reply With Quote
Old   April 4, 2013, 06:14
What do you want to do with the data? What does the data represent? If it represents a scalar field over a mesh then you will have to look at file/open in CFD-Post for the file formats it accepts.
liuzexiang likes this.
Old   April 4, 2013, 06:33
mohammad
The data is the pressure field over a circular plane. And I want to use CFX-POST for calculation of average values on some radial strips. I know how to do it in CFX -POST ,however, i don't know how to use other postprocessing softwares (such as TECHPLOT") for this aim.. Therefore, I prefer to use CFX-POST.
Anyway!
Thanks you Glenn
Old   April 4, 2013, 07:22
Lance
Lance is on a distinguished road
If it is .csv file with line and face connectivity you can import it back to cfd-post as a user surface.
Insert > Location > User surface > Method: from file
Lance is offline   Reply With Quote
Old   April 4, 2013, 08:32
mohammad
Thanks a lot Lance.
It does work.The file and its nodal values can be imported successfully. However, some of the geometrical features,such as creating "Clip surfaces" and ... are not possible, because there is no CFD domain . I tried different tricks to link the CSV file to another domain, but I could not make it.
Old   April 20, 2014, 05:19
liuzexiang
liuzexiang is on a distinguished road
i get the current density z of node at a surface, then compute the dissolution value along z axis, so new node is produce by the old node subtract the computed dissolution value. how to import into the CFD post. i want to see the deformation of the surface. i replace the old data, and save the csv file ,then import the saved csv file by importing surface data or using the user surface, there is error, i don't know why
liuzexiang is offline   Reply With Quote
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
