Linear and quadratic loss coefficients of porous domain |
May 21, 2014, 09:11 |
Daniel Laki
Rep Power: 15 |
Hi all,
I'm modelling a valve which has a filter in it. Obviously I'd like to replace the filter with a porous domain, using the directional loss model and I'd define the streamwise loss with the linear and quadratic resistance coefficients. I have set up a parameter study to find the coefficients for my two working fluids (oil at -20°C and 130°C) by calculating the pressure loss through a simplified filter model for the known mass flow rates. Now my problem is that I can find a combination of these coefficients that can reproduce the correct pressure loss for all mass flow rates for the cold oil. However for the hot oil I have to set different coefficient values for every mass flow rate. I have some previous experience with this problem, as this is the second such project of mine. In the previous project I had a different kind of oil at 0°C and 90°C and I was able to find the correct coefficient values. So only the 130°C oil does not seem to "work". What can cause this problem? |
May 21, 2014, 15:08 |
Edmund Singer P.E.
Rep Power: 20 |
What is not working?
Help in porosity for knitted fabric??? Linear or Quadratic resistance coeff | SS460 | CFX | 13 | September 22, 2011 11:43 |
Momentum source / porous loss | ijk | CFX | 5 | May 20, 2011 10:30 |
Porous Domain | ijk | CFX | 1 | August 30, 2010 19:03 |
porous medium - defining loss coeff for two fluids | sudhakar | CFX | 0 | December 9, 2006 08:11 |
porous domain problem | sudhakar | CFX | 6 | November 29, 2006 09:48 |
