Gravity/Buoyancy/Buoyancy reference density in two phase flow |
November 5, 2013, 09:11 |
Jim KIT
Rep Power: 13 |
Hello, im trying to modell a gravity driven two phase flow(air - water) in a pipe in CFX. (pic1.) Boundary: Velocity Inlet Pressure outlet up pressure outlet down Model: inhomogene Euler/Euler Accordint to cfx, flows in which gravity is important can be modeled by CFX by the inclusion of buoyancy source terms. For buoyancy calculations, a source term is added to the momentum equations as follows: S= (rho - rhoRef) * g For multiphase flows, it is important to correctly set the buoyancy reference density(rhoRef). For a flow containing a continuous phase and a dilute dispersed phase, you should set the buoyancy reference density to that of the continuous phase. so the reference density of the continuous phase cancels out buoyancy( eq. 1) and pressure gradients in the momentum equation of continous phase. For non-dilute cases (which include all free surface cases), all terms can be equally important for each fluid. if there is a significant difference in density you should choose the density of the lighter fluid (that cancels out buoyancy of lighter phase) because this gives an intuitive interpretation of pressure (that is, constant in the light fluid and hydrostatic in the heavier fluid). I've tried using the two limiting cases. if (rhoRef = rhoAir), no mass flows through the upper outlet. if (rhoRef= rhoWater) no mass through the lower outlet, also the hole tank is full of water and bubles come out. If (rhoAir <rhoRef < rhoWater) it works, but i think it is not phiscally correct. In my opinion it shoulde be define as a function. When I try to define rhoRef as a function of Volume fraction, (rhoRef = Air.Vf * rho.Water + (1- Air.Vf) * rho.Air) ther is this error message: The parameter 'Buoyancy Reference Density' is defined to be "Single Valued" but it depends on the following field valued variables: , Air.density, Air.vf, Water.density. have any one any idea, how can I solve this problem? thx for ur time |
November 5, 2013, 17:19 |
Rep Power: 143 |
I think you misunderstand the purpose of the reference value. The exact value of this parameter should not matter and it certainly does not vary over the domain. It is a single value used to reduce numerical round-off. You should be able to double or halve it and results are unaffected.
If changing the reference value changes your results then you have a very sensitive simulation and you should be using double precision numerics. |
November 6, 2013, 01:26 |
Jim KIT
Rep Power: 13 |
thx for your antwort.
Correct me if I wrong. I dont think so. Simply do the tut 9 and change the ref.Density and see the diffrence. However When you see the NS.eq, you find out, that ref.Den has enormous influence. Viele Grüße, |
November 6, 2013, 05:58 |
Rep Power: 143 |
The tutorials are only to show you how to get the models running. They unfortunately do not show you good CFD practise. It the tutorial result changes with different reference densities then it needs double precision numerics as well.
You cannot have a result which relies on precise definition of a reference condition. You cannot do accurate CFD unless this is the case. |
November 17, 2013, 05:50 |
Jim KIT
Rep Power: 13 |
hat any one any other idea to simulate such a separator???
November 19, 2013, 23:14 |
Erik
Rep Power: 23 |
What values are you using for your pressure outlets? These two values are determining your flow, and also the height of your liquid head along with the buoyancy forces. Sounds like you are setting them at the same pressure? Which is not true, and would explain why you are getting your results.
November 20, 2013, 09:45 |
Jim KIT
Rep Power: 13 |
thx for the antwort.
I use the same pressure for both pressure outlet, p(atm) physically this should be so, since both leave out in the environment. can you explain me plz more, I should put pressure at out differently??!!! |
November 20, 2013, 09:59 |
Jim KIT
Rep Power: 13 |
Also, I do not understand it.
the water is at the bottom when Rho(ref)=Rho(air). This should physically lead to lower outlet is clogged and thus the air goes out from the other outlet, but it does not, it even comes out of the lower but not omit from the upper. I mean the transport eq for air hat no extra force-term that it force to go out from upper outlet. I mean, the only reson why air shoud goes out from the upper outlet is that the lower outlet is clogged with water or am I wrong??? |
November 20, 2013, 16:15 |
#9 |
Rep Power: 143 |
A picture showing what you are describing would help.
November 21, 2013, 13:52 |
#10 |
Erik
Rep Power: 23 |
The botom and top should not be at the same pressure. The bottom would be at a higher pressures
due to the liquid head. |
June 9, 2014, 10:23 |
#11 |
Atit
Adding the momentum source should not provide the correct answer. After specifying the Buoyancy reference density and the gravitational acceleration components, CFX will manage the buoyant effect for you. Try to disable this momentum source. It might work. Good luck.
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 09:38 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Compiling new Solver with wmake | lin123 | OpenFOAM | 3 | April 13, 2010 14:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem on boundry of two phase flow | youngan | CFX | 0 | June 30, 2003 02:32 |
