how to set supercritical C02 material
Like Tree5Likes
Old   June 4, 2014, 05:03
Default how to set supercritical C02 material
Cafard
Cafard is on a distinguished road
hi,all
i knew how to set CO2 gas and CO2 liquid
but now i have to simulate a cycle
every state is supercritical CO2
i don't know how to set material....
if someone know how to set or where i can download database
please help me
THX all~
Cafard is offline   Reply With Quote
Old   June 4, 2014, 07:00
Erik
evcelica is on a distinguished road
Just input the properties, what do you need? Supercritical CO2 properties? I use NIST RefProp for all fluid properties.
Cafard likes this.
evcelica is offline   Reply With Quote
Old   June 4, 2014, 07:33
Cafard
thank you,evcelica
i really need supercritical CO2 properties
but i don't know what is NIST RefProp
could it direct input to CFX material
if it is,how could i get it?
THX
Old   June 5, 2014, 09:24
Erik
Use Real Gas option:
Molar Mass: 44.01kg/kmol
Critical Temp: 304.13 K
Critical Pressure: 1070 psia
Critical Density: 467.6 kg/m^3
Acentric factor: 0.22394
Fourth Order Coefficients: (Range: 304.13K to 600K)
CPo/RCO2 = 4.28465E-09*T^3 - 1.00172E-05*T^2 + 0.010372394*T + 2.149248005
a1 = + 2.149248005
a2 = + 0.010372394 [T^-1]
a3 = - 1.00172E-05 [T^-2]
a4 = + 4.28465E-09 [T^-3]
a5 = 0 T^-4
Use default kinetic theory options for viscosity and conductivity.
*No Warranty Expressed or Implied*
Cafard likes this.
Old   June 5, 2014, 10:20
Cafard
thank you,evcelica
the process i do is :
1.) import library data
2.) choose redkw.ccl
3.) import real gas combustion > CO2
4.) change Fourth Order Coefficients (as what you say)
does it CO2 material can simulate supercritical state?
(does the CO2 material > basic setting > thermodynamic state > gas is right? or change gas to liquid?)
i have done some easy case to prove the setting is right
but when i compare the simulate result with NIST RefProp deta
the error is 20% at least
(even i use real gas combustion>CO2 default setting)
Old   June 5, 2014, 17:50
Erik
You can leave it as gas, or don't specify anything. It will give you properties for the supercritical state as far as I'm aware. I just did a simulation using this method for helium, and it came out in agreement with other published data.
I didn't import any .ccl data, I just made my own material, but it sounds like it should come out with the same results.
How are you comparing it to RefProp data?
Cafard likes this.
Old   June 5, 2014, 23:34
Cafard
in CFX-Post i use probe to find one point state
then i key the pressure and temperature to find density (RefProp)
i try to create a new material
and follow the process as you say
but the CFX-Pre warring that i need Thermal Conductivity and Viscosity
then i turn on Transpot Properties (Viscosity and Conductivity)
and use the same as real gas combustion>CO2 set
i also set max./min. temp. and pressure to simulate work condition
but the result still wrong
i have searched on internet for days
i found some method that import a excel data or RGP file to create new material
but i don't how to do it or create RGP file
Old   June 9, 2014, 14:17
Kevin Hoopes
khoopes is on a distinguished road
I have done simulations with supercritical CO2 in CFX using an RGP table generated by REFPROP. It is not a straight forward process, I would recommend contacting ANSYS support and they can walk you through it.
Cafard likes this.
khoopes is offline   Reply With Quote
Old   June 23, 2014, 01:33
Cafard
hi , khoopes
thanks for your recommend
but I still want to know how to simulate S-CO2 state by using "real gas combusion > CO2" data
I have studied for a week,I found some parameter can be seted (advance option or expert parameter),does it have to set?
Old   March 23, 2016, 14:26
Kevin Hoopes
You use refprop to generate a table and then CFX uses the table during the computation. I would contact ANSYS support and they can set you up with the refprop table generator.
Old   March 23, 2016, 20:30
turbo is on a distinguished road
If you move around all state changes in the cycle, you need to use the RGP file instead of R-K fits.
turbo is offline   Reply With Quote
Old   April 13, 2016, 11:47
Dinar
Dinar is on a distinguished road
I hope this will be helpful:
https://www.reddit.com/r/CFD/comment...al_properties/
Dinar is offline   Reply With Quote
Old   April 14, 2016, 02:49
Maxim
-Maxim- is on a distinguished road
guys... this thread is 2 years old...
-Maxim- is offline   Reply With Quote
Old   May 19, 2016, 09:33
Default Super critical water reactors
  #14
ibraheem.215 is on a distinguished road
Dear
You can generate the properties of any fluid through REFPROP like viscosity, density, thermal conductivity etc. But this software is not available online. I am simulating the same problem by using supercritical water but i am facing convergence issues. If you guyz know about this. My channel is 2*2 rod bundle with constant heat flux and water at 25MPa
ibraheem.215 is offline   Reply With Quote
Old   October 6, 2016, 08:07
Default Convergence Issue
  #15
Senthilkumar
aero.senthilkumar is on a distinguished road
Dear all,
I am trying to simulate SCO2 flow through convergent divergent duct and 11 bar and 340K with Fluent. When I used ideal gas EOS, solution getting converged. But when I try to use with other EOS(RK, PR, NIST), I am getting divergence after some iterations.
My case details are:-
Steady flow
Density based solver
Please reply. Thanks in advance.
Regards,
Senthilkumar
aero.senthilkumar is offline   Reply With Quote
Old   October 10, 2016, 04:25
alirezame is on a distinguished road
Due to low compressibility factor of CO2 near the critical point and inside the supercritical dome, ideal gas assumption decreases the accuracy of the result significantly. plz tell more information and what have you done to prevent divergence? (time step, discritization, look-up table range and size, initial solution, boundary conditions, ...)
alirezame is offline   Reply With Quote
Old   October 16, 2016, 12:13
Senthilkumar
Dear alirezame,
Here is the details of my settings.
Timescale I set as "Auto",
Discretization as "Upwind" for initial iterations then "High Resolution",
Look-up table range "217K-1100K" ; "0.1 Pa - 100e5 Pa" with data points of 800.
For real gas simulation initial solution is "Results with Ideal gas EOS"
My domain simple C-D Nozzle, Inlet as Inlet BC with total pressure of 11 bar and temperature of 320K ( I tried with initial temperature of 500K, but when I tried to decrease slowly to 320 , I facing error "retrun with code-1" in cfx)
Outlet BC is "supersonic"
Please correct me where I am going wrong.
Your reply will be much helpful.
Thanks.
Greg Hwang likes this.
Old   October 17, 2016, 06:14
I would recommend to not use super sonic boundary condition in first simulation. use outlet pressure first and after getting convergence change the boundary condition to super sonic.
Old   October 23, 2016, 08:42
Alex
alex-bishop is on a distinguished road
hello! can i ask you a question about how to generate a table of SCO2 by NIST? i want to import this table into CFX.
if you have some more direct method please tell me too. for example setting in CFX-pre directly.
alex-bishop is offline   Reply With Quote
Old   August 17, 2019, 06:53
Default How to set supercritical CO2 properties?
  #20
Jane
Fresher is on a distinguished road
[QUOTE=evcelica;495712]Use Real Gas option:
a1 = + 2.149248005
a5 = 0 T^-4
Hello,evcelica~
Thanks to your advice.I've succeeded in computing with these settings you'd given.But I still wonder how the expression "CPo/RCO2 = 4.28465E-09*T^3 - 1.00172E-05*T^2 + 0.010372394*T + 2.149248005"came from.
If anyone there know that,please help me.I'll appreciate a lot.
Fresher is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
How to set particle material in DPM panel romans FLUENT 8 June 4, 2008 20:49
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Install Openfoam in Suse 100 setup environment h34gk1 OpenFOAM Installation 1 September 26, 2006 20:08
