Vortex shedding frequency from cylinder
Like Tree1Likes
  • 1 Post By markomilosevic
Old   July 12, 2016, 09:12
Question Vortex shedding frequency from cylinder
Matt
UOWmecheng is on a distinguished road
Hey everyone, I'm trying to simulate VIV of a rigid cylinder in CFX. After running the file and exporting data I found that the lift coefficient fluctuates at a frequency of 1.39 Hz, however the shedding frequency as estimated by the Strouhal number is 0.97 Hz. In post-CFD I found that y+ max is ~6.4 and the max courant number is ~0.25. Does anyone have a suggestion to get the shedding frequency closer to that predicted by the Strouhal number? Any help is greatly appreciated!
UOWmecheng is offline   Reply With Quote
Old   July 12, 2016, 17:14
marko milosevic
markomilosevic is on a distinguished road
Hi Matt,
what Re are you dealing with, and what numerical solution did you use
UOWmecheng likes this.
markomilosevic is offline   Reply With Quote
Old   July 12, 2016, 20:39
Matt
Hi Marko,
The Re is 10 000 and I am using DES
Other specs: fluid is water with density = 1000 kg/m^-3 and dynamic viscosity = 1.16E-3, cylinder diameter = 0.05m, first layer mesh height = 1E-4m, velocity is steady in x direction with magnitude 0.232 m/s
Old   July 13, 2016, 01:30
urosgrivc
urosgrivc is on a distinguished road
I wonder if SAS SST with y+~1 would predict the frequency even better:
How did you model the elastic part of your simulation (rigid body springs?)
For VIV mass of the cilinder and springs will efect the solution frequency also, not just the fluid that is surounding your cilinder.
Cilinder must have the wright amount of inertia as it will be prone to acelleration and decellerations.
Are you doing a 2D or 3D?
Is your domain big enough?...
It is a nice case you have got there, I want to be informed of what you will come up with and what you will be able to achieve.
This was also done with cfx I think it is quite nice and hope you will get there.
It is just a fixed cilinder but the frequency looks to be spot on.
https://www.youtube.com/watch?v=mNQ9NRdrKCM
It would be nice to get a lot of data of this reserch than compare the results, my future plans;
https://www.youtube.com/watch?v=9FRTj6_1J2k
urosgrivc is offline   Reply With Quote
Old   July 13, 2016, 20:06
marko milosevic
ok, not expert but trying to solve similar situations... I would observe frequency with realisable k e with first layer height between 30-300y+, and coefficients drag/lift with sst and first layer 1y+, and 10 cv in sub/buffer layer, and check correlation with literature, and than move to des and les... as things are going with me les is solution, inform me what results you got with des, how big is your domain and mesh quality
Old   July 14, 2016, 02:15
urosgrivc
Are you doing:
A = a VIV simulation with oscilating cilinder
or
B = just wortex sheding with stationary cilinder?
Old   July 14, 2016, 12:33
marko milosevic
scoping thru vortex shedding phenomenon, to see range of interest viv for chimneys, finishing with viv for one case , but did a range of re... as it is air, I am neglecting mass of air vibrating with cylinder, so the case is different, not water... would compare what I can get from vortex shedding and structural dynamics, and later viv simulation
Old   July 14, 2016, 19:05
Before you dive into the complexities of turbulence modelling - have you checked the basics? See FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
If you have not checked that your time step, mesh and convergence tolerance are correct then you are wasting your time looking at the turbulence model.
courant number, vortex shedding, vortex shedding frequency, yplus
vortex shedding frequency naveen OpenFOAM 23 May 17, 2016 08:12
Vortex Shedding in a 2D cylinder Using buoyantBoussinesqPimpleFoam veerag96 OpenFOAM 0 April 16, 2016 22:22
Cylinder vortex shedding (3D) Apocolapse STAR-CCM+ 2 April 3, 2014 20:33
frequency of vortex shedding HaKu Main CFD Forum 3 March 18, 2011 00:00
3D cylinder and Vortex Street shedding issues josik_1982 FLUENT 2 July 17, 2010 10:19
