heat release rate in output file
Like Tree1Likes
  • 1 Post By matej
Old   February 3, 2005, 20:55
Default heat release rate in output file
Caty
does anyone know how to get the chemical heat release rate in the output file?
I need to model a fire that has a heat release of 100 kW and i don't know how to calculate the velocity that must be set at the inlet to coresspond to a heat release of 100 kw.
Can you help me with this?
Thnak you, Caty
Old   February 4, 2005, 02:53
Default Re: heat release rate in output file
matej
(1)you can get the total heat output in out file if you read the heat going in and heat going out the domain. its at the end of out file. You can also plot it, if you make a additional variable given by expression, where you can set Material.ReactionRate (or what is the name of it) and mutliply it with the Heat of reaction. If you define a variable for it, you may see the change of heat release in the domain, if you are happy with summs or averages in volumes or sections, you just use summ or average ot whatever function of ccl and set to monitor this expression in the output setting in pre. It also depends on the combustion model you use...
(2)It is not difficult. For example the velocity of fuel can be given as:
vel=Power/(rho*ReactionHeat*Area)
where Power = 100 kJ/s, Area = is the inlet area
matej
raajgovindan likes this.
Old   February 8, 2005, 19:23
Caty
Thank you very much Matej. I will do as you suggested.
Have a nice day,
Caty
Old   February 14, 2005, 07:08
caty
Hi Matej,
I calculated the fire in the way you said, but i think something may be wrong...Can you please have a quick look maybe you figure out what is wrong...
The concrete fire is: Fuel; Propane Power= 980 Kw The burner = 0.61m*1.22 m Reaction Heat= 1650 kj/mol= 37.41 kj/g Fuel density = reference density = pref /(R/mwMixIn*Tref) T ref = 300 mwMixIn= vfC3H8*mwC3h8+vfO2air*mwo2air pref=1010325 Pa ===> Fuel density = 2.2 kg/s Velocity = power / Raect Heat*fuel density*Area =„» velocity= 0.015 m/s
The velocity is seems a little bit to small and I am wondering maybe I did something wrong (the case seems hard to converge).
Do you think that I set the fuel density correct? How you choose this?
caty
Old   February 14, 2005, 07:09
caty
The velocity is seems a little bit to small and I am wondering maybe I did something wrong (the case seems hard to converge). Do you think that I set the fuel density correct? caty
Old   June 13, 2014, 02:21
Default heat release rate in Fluent
Rajesh
raajgovindan is on a distinguished road
hello
can anyone suggest me how to get data of heat release rate for combustion modeling of diesel engine. I am using eddy dissipation model in Fluent...
regards
Rajesh
raajgovindan is offline   Reply With Quote
Old   June 16, 2014, 11:06
Edmund Singer P.E.
singer1812 is on a distinguished road
Try Fluent forum...
singer1812 is offline   Reply With Quote
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 18:49
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
calculation of heat release rate paul Siemens 3 February 16, 2006 03:40
About heat release rate in STAR/CHEMKIN module vigorzxy Siemens 0 June 10, 2005 04:07
