DSDP_H and DSDP_T properties
Old   July 17, 2014, 00:37
Default DSDP_H and DSDP_T properties
Stephen Waite
Stephen Waite is on a distinguished road
Hello, I'm simulating flow with a variable composition mixture with three components (air ideal gas, CO2 at STP and H2O) however when I go to run the simulation I get the following errors:
"The property DSDP_T is only present in some of the components of the mixture GasMixture"
"The property DSDP_H is only present in some of the components of the mixture GasMixture"
where GasMixture is the name of the variable composition mixture.
I'm unsure about how to change/set these DSDP_T and DSDP_H properties seeing all components of the gas mixture are defined in the CFX materials library.
Thanks in advance for your help.
Stephen Waite is offline   Reply With Quote
Old   July 17, 2014, 06:02
I suspect (but am not sure) that it is looking for ideal gas properties for the CO2 and H2O components. As CO2 and H2O are constant density fluids I would generate a constant density air component at the appropriate condition so all your components are constant density.
cfx, dsdp_h, dsdp_t, multiple gas components, variablecompositionmix
