How to achieve a constant water level in a transient simulation? |
July 14, 2014, 05:01 |
Rep Power: 11 |
Hello everyone,
I´m trying to complete the parameters for a Multiphase Transient Flow simulation in a turbine. Until now, everything seems to go fine except for one condition: I don’t know how to establish a CONSTANT water level in time downstream the rotor. As Initial conditions I configured the volume of fraction as: WaterVF: if(y<Waterlevel,1,0) Waterlevel:-200 mm AirVF: 1-WaterVF (Rotor=rotary domain, Rest=stationary domain) But as time passes by, the water level decreases until I loose it completely. This is expected, since y have a downstream OUTLET (average static pressure -20kpa ) but how can I solve it? I annexed 2 printscreens: t=0 and some seconds after Thank you all in advance. |
July 14, 2014, 06:02 |
Rep Power: 143 |
Isn't this simply saying that your exit pressure is too low? -20kPa sounds like a vacuum to me so no wonder it sucks
Work out what the pressure should be at your exit. |
July 15, 2014, 09:18 |
Rep Power: 11 |
Hello ghorrocks,
True. I realized that specific input data was improper so I changed the boundary to Mass Flow (equal to the inflow). Also, I think a proper counter pressure just enough to handle that water column might work fine. Thank you for your advice. AL |
July 15, 2014, 18:42 |
Rep Power: 143 |
A mass flow inlet and mass flow outlet will not work either. First of all it is numerically ill-defined as the pressure level is not set. And secondly, as a numerical solution is approximate then the inlet flow will not EXACTLY match the outlet flow then you will get a small flow imbalance and this will slowly either fill or empty the domain.
You need to apply a pressure at the outlet equal to the static head of the water column height you want. You are going to have to correct it for the reference density static head as well - have a look at the flow over a bump tutorial for an idea of how to do this. |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
Boundary Conditions - Transient Simulation | miki256 | CFX | 2 | May 18, 2012 01:22 |
Time step in transient simulation | shib | FLUENT | 0 | June 17, 2010 13:07 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
