July 22, 2014, 08:07 |
HTC - turbulence model
Jiri
Rep Power: 13 |
Hi there,
I try to receive HTC values in a conical pipe in which air flows. I ve already tried out many combinations of setting and I ve found out that k-epsilon gives much smaller values (cca twice smaller) of HTC than other turbulence models (SST, k - omega, k-epsilon EARSM etc..). However the results given by k-epsilon fit better to analytical solution.. Do you have any recommendation about turbulence models for HTC ? My y+ is about 10-15 and even smaller y+ gives actually the same results. |
July 22, 2014, 19:08 |
Rep Power: 143 |
What reference temperature have you used for your HTC? Most engineering calculations use a far-field temperature for this (eg free stream temperature), but by default CFX does not use this. If you are comparing to experimental results you should make sure your reference temperature is the same by setting the expert parameter.
So before you look at accuracy or other turbulence models make sure your reference temperature is correct. |
July 23, 2014, 02:06 |
Jiri
Rep Power: 13 |
Thanks for your reply,
I am not sure where to set up reference temperature, cause in the domain I can just set reference pressure. Is it an expert parameter? |
July 23, 2014, 02:37 |
Rep Power: 18 |
Try:
FLOW: Flow Analysis 1 &replace EXPERT PARAMETERS: tbulk for htc = 300.0 END END |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
